63 Pages V « < 52 53 54 55 56 > »
> First of the Texas Twins, First Build
Puebloswatcop
post Jun 11 2025, 06:19 PM
Post #1061
There are several nooks and crannises for rust and other garbage to hide in these doors, like inside the window channel at the top of the door.
Puebloswatcop
post Jun 11 2025, 06:24 PM
Post #1062
There is no way to reach every seam on these doors, short of tearing them completely apart. Since the door was structually sound, I used a wire wheel to get aas many of these places as clean as I could. In the end, I am pretty happy with the door at this point, but then I thought more about how I can treat existing rust and prevent future issues.
Puebloswatcop
post Jun 11 2025, 06:30 PM
Post #1063
So I broke out the Ospho. My father in law swore by this stuff when he was restoring cars and he lived near the ocean. So I decided to treat the hard to reach areas.
Puebloswatcop
post Jun 11 2025, 06:35 PM
Post #1064
I started by getting it into the seam where the door skin is attached to the door frame at the bottm of the door, Then I did all of the front and rear seams and the area that I repaired where the mirror mounts are. I also painted it into the seem at the window channel.
Puebloswatcop
post Jun 11 2025, 06:40 PM
Post #1065
Lastly I put it into the channels at the front and rear of the door where the door seal goes. I painted it in from both the inside and outside seams of the channel to make sure I got good penetration all the way under the channel. I give that 24 hrs to dry and then I'll go back and put a fine bead of seam sealer along the channels to keep any water out od all of the seams.
BillC
post Jun 11 2025, 07:14 PM
Post #1066
That's a great way to treat your doors. I really like Ospho.
However, I recommend that, before you put seam sealer on them, you go over all the seams with a heat gun or torch and make sure they are completely dried out. I have read too many stories of people who dipped their cars to remove the rust and then had their paint fail months later, because there was still liquid in the seams. This includes cars that were allowed to dry for at least a month.
Years ago, I had some parts dipped and, because I had heard those stories, I went over the seams with a propane torch, just enough to heat the metal. Even though I had let the parts sit a week, I still heard some sizzling as the last little bits of fluid boiled out.
friethmiller
post Jun 11 2025, 09:27 PM
Post #1067
Excellent work, Kevin. Ospho works well for getting in the cracks. I recommend trying Rust Bullet’s Metal Blast. It’s even better, IMHO!
Puebloswatcop
post Jun 12 2025, 08:47 AM
Post #1068
QUOTE(BillC @ Jun 11 2025, 08:14 PM) *
Thanks for the info Bill. I didn't think about that. Guess the torch will get a workout this morning.
Puebloswatcop
post Jun 12 2025, 08:48 AM
Post #1069
QUOTE(friethmiller @ Jun 11 2025, 10:27 PM) *
Is it available locally Fred?
Puebloswatcop
post Jun 12 2025, 03:31 PM
Post #1070
After taking Bill's advice, I blew out the channels and seams with compressed air and then used the torch to heat things up to insure all the Ospho was dry. I then painted the inner surface of the door with 2 coats of self etching primer.
Puebloswatcop
post Jun 13 2025, 08:26 PM
Post #1071
Today I skim coated the door. I have been using Evercoat Optex. One thing I like about it is that it changes colors as it dries. When it reaches a greenish gray color you know it has dried enough to sand. It does start to set up rather quickly though, so I do sections of the work so I don't waste product.
Puebloswatcop
post Jun 13 2025, 08:30 PM
Post #1072
Here is a couple of pics to show how it changes. The first section was done earlier in the day. I let it set up while I ran to town. When I got back I did the remainder of the door ( in sections) so the second picture shows the difference in the filler when wet and when completely dry.
Puebloswatcop
post Jun 13 2025, 08:34 PM
Post #1073
I finished coating the entire door and you can see there are still some pink colored areas that are drying. After about 30 minutes though it was ready to sand. It was still a bit soft in the high spots, making it easy to sand those away.
Puebloswatcop
post Jun 13 2025, 08:38 PM
Post #1074
I was going to quit at that point, but I figured what the heck, I was having fun watching the transformation. So I kept sanding. I used an 18 inch sanding block with 80 grit and got most of the door sanded out. I did have a couple of low spots, so tomorrow I will go back in and re-fill those feather them in and then switch to 100 grit.
friethmiller
post Jun 14 2025, 07:55 AM
Post #1075
QUOTE(Puebloswatcop @ Jun 12 2025, 08:48 AM) *
Not sure. I get mine off Amazon.
friethmiller
post Jun 14 2025, 08:05 AM
Post #1076
QUOTE(Puebloswatcop @ Jun 13 2025, 08:38 PM) *
This is how I do my panels (IMG:style_emoticons/default/aktion035.gif). Saves so much time on doors and hoods especially since you can remove and put them on a stand. Once reinstalled, work across the panels with a long block for flatness. You might need more filler to do this. But what you're doing now is the way to go, IMO.
BTW, I'm doing my body work later after I've repaired and roughed in all the doors and hoods. I can't wait for my 2-3 minutes of working time with the filler in August. Going to need to get a mini-frig to keep the bondo cool out in the shed.
Puebloswatcop
post Jun 14 2025, 10:50 AM
Post #1077
QUOTE(friethmiller @ Jun 14 2025, 09:05 AM) *
I know what you mean Fred. I am lucky enough now to have a temperature of 75 degrees to work in. Even at that, it only allows me between 5 and 10 minutes work time to skim the filler. thats what caused one of my low spots, I made the mistake of going back over one spot and ended up pulling some of the filler out. Nothing that can't be corrected. I would offer you a space in the shop to work on it, but the distance is a bit prohibitive....lol
Puebloswatcop
post Jun 16 2025, 03:07 PM
Post #1078
Time to get those low spots and other scratches and such filled in.
Puebloswatcop
post Jun 16 2025, 03:09 PM
Post #1079
There were about a half dozen low spots and scratches in the last fill. One of them I had to fill twice to bring it level...
Puebloswatcop
post Jun 16 2025, 03:12 PM
Post #1080
After filling each one and one twice the hole door was sanded with 80 Grit, then 120 grit,
Then I hit it with high build primer to fill in some of the deeper scratches and protectthe door from rust.
- Lo-Fi Version Time is now: 17th August 2026 - 05:57 PM
