67 Pages V « < 65 66 67
> First of the Texas Twins, First Build
Puebloswatcop
post Nov 12 2026, 03:42 PM
Post #1321
More work on the new wiring harness. Here are a few comparrison pictures of the old next to the new harness. In the old harness you can see the wires for the Oil Temp and the Fuel Pump. In the new Harness the Fuel Pump has been re-located to the front and deleted from the factory install. The new wire for the pump was changed to a 16 Ga. as well. The gap in the harness cover was also closed up for a neater appearance.
Puebloswatcop
post Nov 12 2026, 03:48 PM
Post #1322
I also did the battery hookups today. I heat shrunk the new pairs individually and then closed up the tubing with heat shrink as well.
Here is a look at the rear end of the harness old vs new. Still have a boat load of quick disconnect terminals to put on.
Puebloswatcop
post Nov 12 2026, 03:53 PM
Post #1323
Then spent the rest of the day adding all of the wiring from the 14 pin connector and everything that had to go through the tunnel. Now the rear portion is at a hold again while I wait for the snorkel to be delivered.
Puebloswatcop
post Nov 13 2026, 06:09 PM
Post #1324
Since the doctor told me I could go back to work "as tolerated", I decided to go back to work on the bumper. Figured if it was too hard on the shoulder, it would be easy to put away. I had already worked on the one very high spot, and put a couple layers of high build primer on it, so started off by spraying a guide coat on it.
Then started wet sanding with 120 grit, In the first pic you can see there was a low spot right next to the space where the fog light grill goes in. You can also see the sanding scratches, so I switched to 180 paper. I wet sanded one more time and was able to get things pretty flat. The low spot was not as big or deep as I originally thought, it was about the size of a golfball in the end. there were a cuple of othe lows about the size of a pencil eraser. I hit the low spots with high build primer and resanded them until they blended.
Puebloswatcop
post Nov 13 2026, 06:16 PM
Post #1325
I found out that "as tolerated" came sooner rather than later. I was able to sand for about an hour and my shoulder felt like I had gone to the gym and bench pressed max weight. I was pretty happy with the progress, so decided to put two more coats of high build primer on it to eliminate any thin spots and call it a day. Guess I'll have to take it pretty slow until I can get some muscle built back up in this shoulder.
29 User(s) are reading this topic (29 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 17th November 2026 - 06:57 AM
