Gauging interest in restored window posts |
bdstone914 |
Oct 8 2021, 06:55 PM
bdstone914 Group: Members Posts: 4,512 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I have found a good anodizer and polishing shop and did a batch of horizontal targa bar trim that turned out great. I am going to do a batch of window posts. I have three sets of early and 8 sets of late posts.
Pricing should be about $60 per post. It will require removing out the rivets fro the steel brackets and reinstalling them. Will probably need to replate them while they are off. I need to do several sets at a time to cover the minimum costs. I am good on cores for now to get started but could use more if there is enough interest. Who is in? |
Oct 8 2021, 07:29 PM
914-6 GT in waiting Group: Members Posts: 19,234 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I’m in for an early set. I have some cores if you run low.
JamesJ |
Oct 8 2021, 07:37 PM
Member Group: Members Posts: 219 Joined: 30-April 20 From: Sunnyvale, CA Member No.: 24,202 Region Association: Northern California |
Hi Bruce,
Great timing. I’ll take a late set. Thanks. |
jims914 |
Oct 8 2021, 08:05 PM
Member Group: Members Posts: 123 Joined: 11-March 11 From: Tempe,AZ Member No.: 12,816 Region Association: Southwest Region |
bdstone914 |
Oct 8 2021, 08:32 PM
Hi Bruce, Great timing. I’ll take a late set. Thanks. Bruce, can you show what posts you are talking about (Photo ) @jims914 Here you go. http://www.914world.com/bbs2/index.php?sho...=353851&hl= The shiny one is polished only. The duller ones are anodized. They may look scratched but it is just dust. |
scallyk9 |
Member Group: Members Posts: 317 Joined: 16-October 16 From: Port Orchard, WA, USA Member No.: 20,499 Region Association: Pacific Northwest |
I'd like one set of late model for a 1974.
914e |
Oct 8 2021, 10:42 PM
Member Group: Members Posts: 496 Joined: 21-February 20 From: Arizona Member No.: 23,951 Region Association: Southwest Region |
Yes! I need a set for a 76.
Tdskip |
Oct 9 2021, 06:36 AM
Advanced Member Group: Members Posts: 3,683 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Any chance they will do 911 window frames?
bdstone914 |
Oct 9 2021, 07:39 AM
Any chance they will do 911 window frames? Check the material. Some are chrome plated brass. They have to be completely taken apart. @tdskip |
gms |
Oct 9 2021, 08:04 AM
Advanced Member Group: Members Posts: 2,694 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
Count me in for 5 early sets
sixaddict |
Oct 9 2021, 08:07 AM
Senior Member Group: Members Posts: 796 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
Bruce
I am in for an early set…..have decent cores as well. Perfect timing for me. Terry |
Oct 9 2021, 11:18 AM
Any chance they will do 911 window frames? Check the material. Some are chrome plated brass. They have to be completely taken apart. @tdskip Brass up through 67. 68 is aluminum vent window, 69+ aluminum without vent window. |
Literati914 |
Oct 9 2021, 11:31 AM
Senior Member Group: Members Posts: 1,432 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
one of my cars has early doors and the other late (not taken apart) - quick run down of the differences ?
bdstone914 |
Oct 9 2021, 02:16 PM
PaulFV8 |
Oct 9 2021, 09:45 PM
Member Group: Members Posts: 81 Joined: 2-August 20 From: Virginia, USA Member No.: 24,562 Region Association: None |
A late set for me
Please |
TonyA |
Oct 10 2021, 04:57 PM
Nachmal Group: Members Posts: 460 Joined: 17-November 16 From: Hilltown PA Member No.: 20,596 Region Association: North East States |
Put me in for two sets late 74. i have some cores also if needed.
Thanks, |
bdstone914 |
Dec 15 2021, 09:16 AM
@Mepstein
@scallyk9 @914e @sixaddict @PaulFV8 @Lg914 @PaulFV8 @TonyA Update on the window posts. The polishing is nearly done. After that they go for anodizing and then to rivet on the brackets. I am going to need deposits to cover the polishing cost and anodizing which will be over $1000. I prefer Venmo or Zelle or checks. I will send PM's with that information. I will also need cores from those that can supply them. Some of you have already send cores. I found that several post were not usable as that were twisted or had scratches that were too deep to polish out. Many more were too curved but I made a jig and recurved them. i have enough cores to supply all those that have inquired but want to be able to continue this service. |
Dec 15 2021, 12:30 PM
Bruce - I’m still interested and can send you some me cores. When you pm me, including your shipping address.
I could also use a quote on early 911 aluminum window frames if you are able to do them. Thanks |
bdstone914 |
Dec 15 2021, 03:31 PM
Bruce - I’m still interested and can send you some me cores. When you pm me, including your shipping address. I could also use a quote on early 911 aluminum window frames if you are able to do them. Thanks PM sent @mepstein I am doing a couple pair of early 911 frames. They are a ton of work. It takes about an hour per frame to take apart. Some of the fasteners have the rivet as part of the tab and will take some fab work to put them back together. I need to get thru with these before I take on more work. But it will be ore econimical to do yours at the same time. We can talk later |
Dec 15 2021, 03:39 PM
Bruce - I’m still interested and can send you some me cores. When you pm me, including your shipping address. I could also use a quote on early 911 aluminum window frames if you are able to do them. Thanks PM sent @mepstein I am doing a couple pair of early 911 frames. They are a ton of work. It takes about an hour per frame to take apart. Some of the fasteners have the rivet as part of the tab and will take some fab work to put them back together. I need to get thru with these before I take on more work. But it will be ore econimical to do yours at the same time. We can talk later Sounds good. I can take apart and prep when it’s time. |
Lo-Fi Version | Time is now: 23rd April 2024 - 11:31 AM |
