Gauging interest in restored window posts |
bdstone914 |
Oct 8 2021, 06:55 PM
bdstone914 Group: Members Posts: 4,522 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I have found a good anodizer and polishing shop and did a batch of horizontal targa bar trim that turned out great. I am going to do a batch of window posts. I have three sets of early and 8 sets of late posts.
Pricing should be about $60 per post. It will require removing out the rivets fro the steel brackets and reinstalling them. Will probably need to replate them while they are off. I need to do several sets at a time to cover the minimum costs. I am good on cores for now to get started but could use more if there is enough interest. Who is in? |
mepstein |
Dec 15 2021, 12:30 PM
914-6 GT in waiting Group: Members Posts: 19,272 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Bruce - I’m still interested and can send you some me cores. When you pm me, including your shipping address.
I could also use a quote on early 911 aluminum window frames if you are able to do them. Thanks |
bdstone914 |
Dec 15 2021, 03:31 PM
Bruce - I’m still interested and can send you some me cores. When you pm me, including your shipping address. I could also use a quote on early 911 aluminum window frames if you are able to do them. Thanks PM sent @mepstein I am doing a couple pair of early 911 frames. They are a ton of work. It takes about an hour per frame to take apart. Some of the fasteners have the rivet as part of the tab and will take some fab work to put them back together. I need to get thru with these before I take on more work. But it will be ore econimical to do yours at the same time. We can talk later |
mepstein |
Dec 15 2021, 03:39 PM
Bruce - I’m still interested and can send you some me cores. When you pm me, including your shipping address. I could also use a quote on early 911 aluminum window frames if you are able to do them. Thanks PM sent @mepstein I am doing a couple pair of early 911 frames. They are a ton of work. It takes about an hour per frame to take apart. Some of the fasteners have the rivet as part of the tab and will take some fab work to put them back together. I need to get thru with these before I take on more work. But it will be ore econimical to do yours at the same time. We can talk later Sounds good. I can take apart and prep when it’s time. |
Lo-Fi Version | Time is now: 17th May 2024 - 05:57 PM |
