Gauging interest in restored window posts |
bdstone914 |
Oct 8 2021, 06:55 PM
bdstone914 Group: Members Posts: 4,522 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I have found a good anodizer and polishing shop and did a batch of horizontal targa bar trim that turned out great. I am going to do a batch of window posts. I have three sets of early and 8 sets of late posts.
Pricing should be about $60 per post. It will require removing out the rivets fro the steel brackets and reinstalling them. Will probably need to replate them while they are off. I need to do several sets at a time to cover the minimum costs. I am good on cores for now to get started but could use more if there is enough interest. Who is in? |
mb911 |
Dec 15 2021, 06:02 PM
914 Guru Group: Members Posts: 6,851 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I would be interested in a set.. also still need a new driver side glass. Not the 1/4 window.
bdstone914 |
Dec 15 2021, 09:20 PM
I would be interested in a set.. also still need a new driver side glass. Not the 1/4 window. @mb911 I will see if i have an extra set when i get them back. Do you need early or late? And on the window do you need ckear or tinted? |
56kabrio |
Dec 16 2021, 04:37 PM
Member Group: Members Posts: 54 Joined: 1-December 05 From: Nashville, TN Member No.: 5,219 Region Association: None |
I would be interested in a set.. also still need a new driver side glass. Not the 1/4 window. @mb911 I will see if i have an extra set when i get them back. Do you need early or late? And on the window do you need ckear or tinted? If any of these are still available, I’d like a set for my ‘73. Thanks Mack |
bdstone914 |
Dec 16 2021, 05:31 PM
I would be interested in a set.. also still need a new driver side glass. Not the 1/4 window. @mb911 I will see if i have an extra set when i get them back. Do you need early or late? And on the window do you need ckear or tinted? If any of these are still available, I’d like a set for my ‘73. Thanks Mack I will let you know if i have enough Monday when i pick them up from polishing. I took in a few extra sets. I have had a few other members also want a set. I will do another after this batch. I m going to need cores. @56kabrio |
Lo-Fi Version | Time is now: 17th May 2024 - 09:41 PM |
