Pinout values for 74 1.8 ECU |
L-Jet914 |
Oct 21 2021, 09:56 PM
Member Group: Members Posts: 237 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California |
I recently bought a used 74 1.8 ECU for a backup part if needed. I was wondering if anyone has any pinout values so I can test the ECU to see if it is good. Thank you in advance.
JeffBowlsby |
Oct 25 2021, 03:10 PM
914 Wiring Harnesses Group: Members Posts: 8,507 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I have the EFI Associates testers for both MPC and AFC FI systems. Unable to test the ECU by itself, these testers require the ECU in the car with the rest of the FI system, where the testing cable is interposed at the ECU connection with the EFI harness, and the ECU (and the rest of the FI system) is tested in situ. Individual function blocks of the ECU can be verified using this tester in this way.
Attached image(s) |
Lo-Fi Version | Time is now: 16th May 2024 - 08:59 PM |
