808 WRX |
Member ![]() ![]() Group: Members Posts: 60 Joined: 4-June 20 From: San Jose, CA Member No.: 24,349 Region Association: Northern California ![]() ![]() |
Yes please! (IMG:style_emoticons/default/happy11.gif)
barefoot |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,415 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States ![]() ![]() |
I'm in for 1
Barefoot |
Quinn Moore |
Qmoore ![]() ![]() Group: Members Posts: 117 Joined: 13-July 21 From: Lake Geneva, WI Member No.: 25,718 Region Association: Upper MidWest ![]() ![]() |
I have had quite a few requests to make these over the years, well, they are finally done and in the final production phase! Trying to tie up some loose ends. Been working on these for awhile and should have material for full production just before Thanksgiving. Another part you may not have noticed most of these are cracked. We even made the vinyl longer so that it can tuck under the main targa seal, just like factory. This is actually the 2nd prototype, the 1st one I'm happy with. We had some issues on the 1st one with the metal in the substructure not lining up 100%. Getting the vinyl to adhere and not shrink up too much in this section is also an issue. These are going to be less than the roll bar pads and pricing will be finalized soon. About $99 on GB if I can get about 65 takers. Materials costs are just being finalized. (1) please Thank you, QM |
jrrobertson |
Member ![]() ![]() Group: Members Posts: 51 Joined: 28-December 16 From: Wolverine Lake , Michigan Member No.: 20,704 Region Association: Upper MidWest ![]() ![]() |
I would like one.
targa72e |
Member ![]() ![]() Group: Members Posts: 287 Joined: 11-September 16 From: colorado Member No.: 20,392 Region Association: None ![]() ![]() |
I would like 1 as well.
john |
Dobbsy |
Newbie ![]() Group: Members Posts: 49 Joined: 22-May 14 From: West Midlands Member No.: 17,382 Region Association: England ![]() ![]() |
1 for me please,
Montreal914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,878 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California ![]() ![]() |
Interested, but I wish the Targa bar issue could be solved first. (IMG:style_emoticons/default/dry.gif)
gms |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,725 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest ![]() ![]() |
The upper picture is the 70. @Mikey914 @bdstone914[/b] Are you talking about the roofs themselves? They definitely are different. Yes I am referring to the different shape if the top that is covered by the pad. The early top is on the right and late on the left. It may be possible that one pad can fit both. Looks like the later tops had a thinner web at the front and had raised bosses for both the targa latch mounting and screw holes for the pad. This is the part that mounts to the top of the window frame (not the Targa) right @Mikey914 ? |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
The upper picture is the 70. @Mikey914 @bdstone914[/b] Are you talking about the roofs themselves? They definitely are different. Yes I am referring to the different shape if the top that is covered by the pad. The early top is on the right and late on the left. It may be possible that one pad can fit both. Looks like the later tops had a thinner web at the front and had raised bosses for both the targa latch mounting and screw holes for the pad. This is the part that mounts to the top of the window frame (not the Targa) right @Mikey914 ? You are correct It’s the same one that if you use urethane to install a windshield gets destroyed when you have to replace the windshield. Ask me how I know. |
Jmb10001 |
Newbie ![]() Group: Members Posts: 3 Joined: 15-November 18 From: Dunn NC Member No.: 22,654 Region Association: South East States ![]() |
I’m in for 1
jcschuf1 |
Newbie ![]() Group: Members Posts: 14 Joined: 23-September 12 From: Maple Grove, MN Member No.: 14,969 Region Association: Upper MidWest ![]() |
Also in for one, thanks!!!
saladin |
Member ![]() ![]() Group: Members Posts: 54 Joined: 18-September 07 From: Mountain View, CA Member No.: 8,125 Region Association: Northern California ![]() ![]() |
I am in for one...if not too late.
Mikey914 |
Nope, we have test fit and sent to another customer to provide feedback and going into production now.
Your on the list |
barnfind9141972 |
Member ![]() ![]() Group: Members Posts: 101 Joined: 10-December 20 From: Rancho Mirage, CA Member No.: 24,976 Region Association: Southern California ![]() |
I’m in too if it’s not too late!
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,491 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Count me in for 3.
Clay |
Flat6forlife |
Newbie ![]() Group: Members Posts: 3 Joined: 4-October 18 From: Babylon, NY Member No.: 22,542 Region Association: North East States ![]() |
Count me in for one, too!
strawman |
Senior Member ![]() ![]() ![]() Group: Members Posts: 891 Joined: 25-January 08 From: Los Osos, CA Member No.: 8,624 Region Association: Central California ![]() ![]() |
Count me in for one.
targa72e |
I would be in for 1
john |
Zimms |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,415 Joined: 11-February 06 From: Michigan Member No.: 5,565 Region Association: Upper MidWest ![]() ![]() |
In for 2
Mikey914 |
Will be ready after Thanksgiving!
Lo-Fi Version | Time is now: 1st August 2025 - 02:40 PM |
