Fuel tank, Mesh strainer removal |
EJP914 |
Oct 24 2021, 06:05 PM
Member Group: Members Posts: 260 Joined: 14-June 03 From: Monroeville, PA Member No.: 821 |
Going to have my gas tank cleaned and coated. I'm guessing the silver colored washer shown in the picture is the bottom of the strainer / screen? How to remove it? Its stuck in there pretty good. Can I pry out with a small screwdriver or grab with pliers and pull. Didn't want to get too crazy on it and damage the adjacent threads.
Any other suggestions are appreciated. Thanks. Ed |
914werke |
Oct 24 2021, 07:14 PM
"I got blisters on me fingers" Group: Members Posts: 10,097 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Unless you are trying to save it grab it with anything & pull, Id use a utility knife to get under it
76-914 |
Oct 24 2021, 09:52 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,505 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
They melt quickly when heat is applied with a butane torch. But since it may harbor fumes you'd need fill the tank with water first. (IMG:style_emoticons/default/beerchug.gif)
Tdskip |
Oct 25 2021, 05:48 AM
Thin screwdriver under the lip to pry it free will work as well.
jrmdir |
Oct 25 2021, 06:34 AM
Member Group: Members Posts: 224 Joined: 13-May 21 From: Central Ohio Member No.: 25,544 Region Association: Upper MidWest |
They're not expensive and I assume you're getting a new one for your clean tank, so pry away. My old one came loose pretty easily. You could also try a screw extractor to break the ring loose.
Ron |
Lo-Fi Version | Time is now: 24th May 2024 - 06:22 PM |
