Exhaust materials question. |
mb911 |
Oct 26 2021, 01:23 PM
914 Guru Group: Members Posts: 6,819 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I am sure by now everyone understands by now the dire shortage on almost everything right now. Stainless is no exception. I have enough material to make 50 more mufflers and then that's it. I can't afford to sit on 2-3 times the material costs to make the same qty of mufflers moving forward. I have long contemplated making steel versions of my mufflers and headers for both the 4cyl and 6cyl cars.
it is a way to keep everything affordable and continue the awesome design. It doesn't mean I would never make Stainless products any further but would mean that there could be a cheaper option. So the question is would it be something folks would buy? I am not sure how many 1000 dollars would sell out of Stainless but I think steel for under 425ish would? Thoughts? |
bdstone914 |
Oct 26 2021, 04:16 PM
bdstone914 Group: Members Posts: 4,515 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I think there would be a market for a lower cost steel muffler. All the originals were steel and held up for many years.
sixnotfour |
Oct 26 2021, 04:19 PM
914 Wizard Group: Members Posts: 10,418 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
A Shop I know, Tried to buy a M&K 911 muffler.. None, No Stainless..
Van B |
Oct 26 2021, 04:36 PM
Senior Member Group: Members Posts: 1,582 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None |
So, this is fortuitous timing. I had in mind to PM you about an exhaust setup for my 74 1.8.
One of the things I was going to ask was whether or not you had considered working with jet hot to ceramic coat your exhaust. I did a bit of a custom set up on my 911 and even though it was stainless, I ceramic coated everything but the exhaust tips. The reduction in heat is significant. And I can tell you through years of using jet hot ceramic on my race bike, it holds up real well for a very long time. High heat ares like the collector will lose a bit of the luster, but the coating will hold up just fine. The best part is, if you are looking to make some exhaust out of mild steel, this can negate the corrosion issue and still deliver a reduced cost to the customer. I be happy to be at the top of your list for a system such as this. -Van Attached image(s) |
mb911 |
Oct 26 2021, 05:08 PM
mb911 |
Oct 26 2021, 05:09 PM
So, this is fortuitous timing. I had in mind to PM you about an exhaust setup for my 74 1.8. One of the things I was going to ask was whether or not you had considered working with jet hot to ceramic coat your exhaust. I did a bit of a custom set up on my 911 and even though it was stainless, I ceramic coated everything but the exhaust tips. The reduction in heat is significant. And I can tell you through years of using jet hot ceramic on my race bike, it holds up real well for a very long time. High heat ares like the collector will lose a bit of the luster, but the coating will hold up just fine. The best part is, if you are looking to make some exhaust out of mild steel, this can negate the corrosion issue and still deliver a reduced cost to the customer. I be happy to be at the top of your list for a system such as this. -Van Van I can make you what you want but at some point they will be stupid expensive unless stainless inventory starts to explode. |
Van B |
Oct 26 2021, 05:54 PM
Ben, maybe I rattled on too much and my point got lost. What I’m suggesting is that you make some systems out of carbon steel, but you jet hot ceramic coat them to avoid rust issues, improve performance, and give a look comparable to 304 SS.
I think you could do all that and still come in at a price point lower than a raw stainless system. Hooker headers uses jet hot for their long tube headers so, I know they do batch pricing. |
Aerostatwv |
Oct 26 2021, 06:01 PM
Member Group: Members Posts: 116 Joined: 13-July 11 From: WV Member No.: 13,315 Region Association: MidAtlantic Region |
Ben, maybe I rattled on too much and my point got lost. What I’m suggesting is that you make some systems out of carbon steel, but you jet hot ceramic coat them to avoid rust issues, improve performance, and give a look comparable to 304 SS. I think you could do all that and still come in at a price point lower than a raw stainless system. Hooker headers uses jet hot for their long tube headers so, I know they do batch pricing. Van, Is the jet hot ceramic process submerged or sprayed on? I would wonder about the internal corrosion if sprayed. But then again, I would think the majority of these cars are kept in the garage and not driven daily anyways. Thanks, Chris |
Van B |
Oct 26 2021, 06:12 PM
Ben, maybe I rattled on too much and my point got lost. What I’m suggesting is that you make some systems out of carbon steel, but you jet hot ceramic coat them to avoid rust issues, improve performance, and give a look comparable to 304 SS. I think you could do all that and still come in at a price point lower than a raw stainless system. Hooker headers uses jet hot for their long tube headers so, I know they do batch pricing. Van, Is the jet hot ceramic process submerged or sprayed on? I would wonder about the internal corrosion if sprayed. But then again, I would think the majority of these cars are kept in the garage and not driven daily anyways. Thanks, Chris They can spray inside and out. But the inside spray isn’t an option for cats or mufflers. It’s then baked on at 400F The coating you see on my car is aluminized ceramic so, it can be re-polished and it reduces galvanic corrosion in some instances of fitment. |
ChrisFoley |
Oct 27 2021, 04:19 AM
I am Tangerine Racing Group: Members Posts: 7,920 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
They can spray inside and out. But the inside spray isn’t an option for cats or mufflers. It’s then baked on at 400F The coating you see on my car is aluminized ceramic so, it can be re-polished and it reduces galvanic corrosion in some instances of fitment. Central Connecticut Coatings in East Hartford has been applying their dual coatings on my mild steel headers for the past 23 years. The exterior appears just as you pictured from Jet Hot, and the interior is dull, lacking the aluminum used in the exterior coating formulation. As far as I know, the interior slurry is applied by a rotating brush on a flexible shaft and the exterior is sprayed on. |
mb911 |
Oct 27 2021, 06:03 AM
Ben, maybe I rattled on too much and my point got lost. What I’m suggesting is that you make some systems out of carbon steel, but you jet hot ceramic coat them to avoid rust issues, improve performance, and give a look comparable to 304 SS. I think you could do all that and still come in at a price point lower than a raw stainless system. Hooker headers uses jet hot for their long tube headers so, I know they do batch pricing. Oh for sure. I knew what you were saying. I do have a local source for that.. its an option |
mate914 |
Oct 27 2021, 08:30 AM
Matt Group: Members Posts: 739 Joined: 27-February 09 From: Eagles mere, PA Member No.: 10,102 Region Association: North East States |
I say yes. Most 4's heat exchangers leak.
I say yes. A $500 6 exhaust would sell. Matt |
barefoot |
Oct 27 2021, 02:46 PM
Senior Member Group: Members Posts: 1,270 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Presume you're using 304 or 304L, have you looked into something like 410 which should be a much cheaper alloy ?
Not sure what OEM automakers are using, but exhaust systems seem to last the life of the car nowadays Barefoot. |
Sea Rooster |
Oct 27 2021, 05:40 PM
Member Group: Members Posts: 106 Joined: 8-March 18 From: Nashville, TN Member No.: 21,948 Region Association: South East States |
I bought a Dansk for my 73 2.0 and it to loud for me. I hate the sound. If I could get a less expensive replacement that is quieter and throaty I would go for it...
mb911 |
Oct 27 2021, 06:21 PM
I bought a Dansk for my 73 2.0 and it to loud for me. I hate the sound. If I could get a less expensive replacement that is quieter and throaty I would go for it... Well ask @Buddyv about mine. It's perfect sound level and construction but not long term sustainable. Stainless shortages will drive the retail upwards of 1200.. I retail now at 850 . Just blows me away we are in this situation. |
914_teener |
Oct 27 2021, 06:44 PM
914 Guru Group: Members Posts: 5,197 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
I bought a Dansk for my 73 2.0 and it to loud for me. I hate the sound. If I could get a less expensive replacement that is quieter and throaty I would go for it... Well ask @Buddyv about mine. It's perfect sound level and construction but not long term sustainable. Stainless shortages will drive the retail upwards of 1200.. I retail now at 850 . Just blows me away we are in this situation. I'd go with ceramic coatings and mild steel like Van is saying. One of the posting is correct they actually perform better and steel is more stable as a material with with heat....it's expansion is more linear than CRES which expands in different directions along with crevice corrosion which makes it have a tendency to crack. My .02 from my materials backround.....from what I can remember. (IMG:style_emoticons/default/slits.gif) |
Oct 27 2021, 07:14 PM
914-6 GT in waiting Group: Members Posts: 19,253 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I bought a Dansk for my 73 2.0 and it to loud for me. I hate the sound. If I could get a less expensive replacement that is quieter and throaty I would go for it... Well ask @Buddyv about mine. It's perfect sound level and construction but not long term sustainable. Stainless shortages will drive the retail upwards of 1200.. I retail now at 850 . Just blows me away we are in this situation. It’s hard to know if this is the new normal or just a peak that will go back to previous levels once production increases. My guess is it will all settle down but take longer to get there than we want. |
Sea Rooster |
Oct 27 2021, 07:26 PM
I bought a Dansk for my 73 2.0 and it to loud for me. I hate the sound. If I could get a less expensive replacement that is quieter and throaty I would go for it... Well ask @Buddyv about mine. It's perfect sound level and construction but not long term sustainable. Stainless shortages will drive the retail upwards of 1200.. I retail now at 850 . Just blows me away we are in this situation. Are there any sound clips available? Seriously contemplating the move... |
BuddyV |
Oct 27 2021, 07:37 PM
Robert Group: Members Posts: 555 Joined: 8-April 05 From: Santa Rosa, CA Member No.: 3,898 Region Association: Northern California |
Buy Ben's "quiet" for the 4 cylinder before you regret it...... his current price is a steal for what you get: beautiful product, hand made, well designed .
I have a 2056 motor on stock FI I have tried everything from Bursch (which I believe made the most power, to Triad, to stock 2.0, to Ben's LOUD dual center muffler...... THIS quiet muffler is the best looking and best quality by far..... and the sound level is just right (for me). Ben's loud model was awesome.... made my car sound like a 6...... really..... maybe BIGGER! But I am getting older, and it was just too loud for me most of the time. I am keeping it for when I need to feel a bit younger (IMG:style_emoticons/default/smile.gif) I still have my stock 2.0 muffler that I might sell..... it was good..... I liked it..... but it is only getting older, and I like shiny things, so Ben's is my choice. As soon as I ran the quiet muffler I noticed the car idled better, and driving seemed to have ideal back pressure...... it's only a seat of my pants review, but it was perfect for me after trying so many others over the years. Wait a few weeks and I would not be shocked if his prices increase by 50% Don't say I didn't tell you so. Thanks, Ben...... excellent design. I even like the way it looks on the car.... cheers! Robert ps - contact me if you are interested in the stock muffler. They are getting more difficult to find |
speed metal army |
Oct 27 2021, 09:54 PM
Waiting for the rain to stop... Group: Members Posts: 1,068 Joined: 4-September 10 From: PNW Member No.: 12,137 Region Association: Canada |
The ceramic coating on MS works and is a fine option. SS pricing will settle down eventually, but this is a no brainer as a second option.
Why not I say! Offer SS and MS coated options. As a stainless guy, even I went MS coated recently. It made sense. Same performance ultimately and will last. Not as pretty, but whateva. It still looks pretty good to me. |
Lo-Fi Version | Time is now: 3rd May 2024 - 04:22 AM |
