MPS rebuild, mission accomplished |
emerygt350 |
Oct 27 2021, 12:07 PM
Advanced Member Group: Members Posts: 2,087 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
I just used Chris Foley's excellent rebuild kit on my leaky MPS. After removing the spider webs and varnish it all went together nicely. Chris gave me some great tips on getting an initial set. I think it is there but I don't have any experience with how a well tuned djet 2.0 914 should run. I suspect there is probably 150k or so on this engine although it could be lower, I doubt higher unless it was cared for very very well. Impossible to know with the dead odometer. Compression is great on all cylinders with no variability.
I took a little video of a drive, start up, corners, and two pulls to 60 (of various quality). After the first 40 seconds I opened my sliding rear window so you can hear the engine sounds better. https://youtu.be/Fi4vFCWhlCw |
emerygt350 |
Oct 27 2021, 01:58 PM
As they would say in Minnesota, uffda, that's a little lean. Turned the inner screw a full rotation to the left. Idle fell to 500, brought it up a little with the idle air screw and then turned the inner screw a hair to the right till it idled nicely again. Really don't want to drill my exhaust for the O2 sensor... Will give it a good drive as soon as I can and check them again.
Quinn Moore |
Oct 27 2021, 03:02 PM
Qmoore Group: Members Posts: 107 Joined: 13-July 21 From: Fox River Grove, IL Member No.: 25,718 Region Association: Upper MidWest |
I just used Chris Foley's excellent rebuild kit on my leaky MPS. After removing the spider webs and varnish it all went together nicely. Chris gave me some great tips on getting an initial set. I think it is there but I don't have any experience with how a well tuned djet 2.0 914 should run. I suspect there is probably 150k or so on this engine although it could be lower, I doubt higher unless it was cared for very very well. Impossible to know with the dead odometer. Compression is great on all cylinders with no variability. I took a little video of a drive, start up, corners, and two pulls to 60 (of various quality). After the first 40 seconds I opened my sliding rear window so you can hear the engine sounds better. https://youtu.be/Fi4vFCWhlCw Did you get the tuning kit as well? Does it come with instructions? I guess that's a question for tangerine. Thought I'd I ask about your experience with the kit. (Since I can't seem to follow directions, i.e "Tech Tips 700", "don't mess with the mps!" @dr914 @autoatlanta.com....I did....so, now I'm ready for instructions on how fix the thing I shouldn't have messed with). Good luck, sounds/looks like your close to getting it dialed in. QM |
emerygt350 |
Oct 27 2021, 03:25 PM
Yes, I got the tuning kit, and well worth it. Chris has given me very good instructions to get it in a good place without the O2 sensor. I was pretty scared at first but I think tuning it is within the range of mere mortals. It really has taken many of the rough spots out. Just need to get it perfect, but at least I feel it is possible with the tuning kit from tangerine.
BeatNavy |
Oct 27 2021, 03:29 PM
The tuning kit does not come with instructions on tuning, but Chris is outstanding about answering questions and supporting his products.
The most detailed documented instructions (that I'm aware of) for tuning are here on Anders' site: https://members.rennlist.com/pbanders/manif...sure_sensor.htm You really need an O2 sensor to get it dialed in. |
emerygt350 |
Oct 27 2021, 03:42 PM
I have a good one but I just don't want to drill the exhaust... For 75 I can take it to a Dyno nearby. I think I will try to get it as close as I can by plugs and ear, then hit the Dyno. That will really get me the definitive wot anyway.
And pbanders is where I started, great info. |
ChrisFoley |
Oct 28 2021, 05:48 AM
I am Tangerine Racing Group: Members Posts: 7,922 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
PB Anders did a great job of characterizing the d-jet system for us but the detailed MPS information tends to intimidate people rather than empower them.
The MPS is a simple mechanical device attached to a robust electronic sensor. Only the mechanical portion is serviceable so I ignore the electronic portion as soon as I know it's operational. I skip the bench tune and go straight to the operational tune. I've come across some simple "seat of the pants" techniques that work well and don't require in-depth knowledge or specialized electronic instruments. The only requirement is that all the components are functioning properly. So far I haven't managed to organize my techniques into a set of tuning notes but it's only a matter of time. For modified engines I always recommend an O2 sensor just after the collector, especially to be sure the engine doesn't go lean at WOT but I don't think it's essential on a stock engine. I don't think spark plug appearance is a very reliable indicator of mixture except at the extremes. A dyno run can verify WOT mixture is safe but the tailpipe sniffers used at most dyno shops aren't accurate for idle tuning. The exhaust gases get contaminated with backwash at very low flow rates. Hot start issues are a good indicator of a lean tune. Properly tuned d-jet starts quickly, hot or cold. Imo most people chasing "vapor lock" issues with their stock injected engines are merely suffering with a lean mixture. I use this knowledge as a tuning tool: Take a drive to get the engine good and hot and then park it for 10 minutes. If it starts right up, the MPS adjustment is pretty good. However if you think it might be a little rich, screw in the small center screw by an eighth turn and try again, starting with a cold engine. One very important thing to keep in mind though: the MPS should never be adjusted to compensate for other issues. Reliable tuning with the MPS can only be done on a properly functioning system. |
JeffBowlsby |
Oct 28 2021, 07:16 AM
914 Wiring Harnesses Group: Members Posts: 8,490 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
...Turned the inner screw a full rotation to the left. Idle fell to 500, brought it up a little with the idle air screw and then turned the inner screw a hair to the right till it idled nicely again. ... Not really sure about what you adjusted, there are two inner screws. |
jrmdir |
Oct 28 2021, 07:49 AM
Member Group: Members Posts: 224 Joined: 13-May 21 From: Central Ohio Member No.: 25,544 Region Association: Upper MidWest |
OP, I hope this doesn't amount to hijacking your thread but it seems we're all in the same boat with this topic. I, too have just finished rebuilding my MPS using Chris' great parts and tuning kit. (When I got the car the diaphragm was toast and it ran rich.)
I made the mistake of buying a very cheap LCR meter on Amazon and had some scary results that I HOPE are the fault of the meter. In all of the write ups the inductance varies from around 1.5 down to .7 ish. On mine, the highest reading never got above .95. Even with nothing touching the operating rod (case apart) Coil resistance is great and inductance changes smoothly across the range, but it just reads too low compared to published data. Chris, then I read your seat of pants input here - set the outer screw to bottom out at around 5"Hg and put everything back together. And lo and behold the drivability is better than it ever was! Now I'm fine tuning and both the inner screw and the ECU knob make noticeable changes. But I'm not sure how to get the right balance. Idle is a bit too high even with the idle screw closed and the whiff test points to rich conditions. I've already ruled out other vacuum leaks and am still somewhat concerned about the low impedance measurements. As it seems that lowering the entire curve would add fuel across the range. But then it seems to drive very well and if I had a bad coil I'm not sure that would be the case. Any thoughts or advice would be appreciated. And if anyone knows of a reference inductor component I could use to spot check the meter it might help. Thanks, Ron |
emerygt350 |
Oct 28 2021, 08:21 AM
I had the exact same inductance readings as well. Both on my original (before the leak developed) and the rebuild with parts from Chris (tangerineracing.com). A range from .6 ish up to a max of .92 no matter what I did. I probably bought the same cheap meter on Amazon. It actually seems like a pretty well made meter though. Would be interesting to check its accuracy, just no clue how to do that.
I adjusted the MPS on the bench as described by Chris (range of movement on the diaphragm running 0 to 7 hg). That is all adjustment of the outer screw. Chris likes the stop screw just starting to engage the diaphragm and I have tried to get that as close as I can since it is in the car now. Just so people know what I am referring to.. I call the big one that plugs the back of the MPS the stop screw and it would normally be covered by epoxy. Chris sells a kit that has this plug screw hollowed out (so you can adjust the inner and outer screws without removing it) with a big 8mm alan for adjustment (and a nice rubber cap to seal it up when not adjusting it). When I say inner screw I mean the tiny innermost screw. When I say outer screw I mean the large screw the inner screw fits into. Once it is on the car I have been adjusting only the inner screw. Chris has a very handy tool for holding the outer screw steady while you rotate the inner screw. (or reverse). |
jrmdir |
Oct 28 2021, 08:48 AM
Yes, that terminology and process is exactly what I'm working with using Chris's tuning kit.
And thanks for the input on your impedance readings - reassuring to know I'm not alone. From what I read coil failures are rare and probably very rare while the resistance is still good. So what are the chances that both of us have exactly the same failure mode? Slim I hope. Maybe an LCR guru can chime in but in the very sketchy instructions that came with my meter it says this: .....when measuring the inductance or capacitance containing a component of resistance it may get the wrong readings. And even more curiously: .. This instrument can not be used to measure the quality of the ICP, the measuring inductance is varied when there is different impedance, you may get the wrong value if you are measuring inductance of the resistance??? Maybe there's a reason why pbanders specified a professional grade LHR? Good luck with the continued tuning. Would be interested to hear if you need to make any big changes after the dyno test. Ron |
ChrisFoley |
Oct 28 2021, 10:25 AM
Idle is a bit too high even with the idle screw closed and the whiff test points to rich conditions. I would be surprised if the mixture is rich. Too high idle indicates too much air, ie. not enough fuel. Proper idle rpm should require some added air from the bypass. |
rjames |
Oct 28 2021, 01:30 PM
I'm made of metal Group: Members Posts: 3,922 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
...Turned the inner screw a full rotation to the left. Idle fell to 500, brought it up a little with the idle air screw and then turned the inner screw a hair to the right till it idled nicely again. ... Not really sure about what you adjusted, there are two inner screws. I'm assuming he's using the definitions from Anders's site. |
rjames |
Oct 28 2021, 01:37 PM
Maybe there's a reason why pbanders specified a professional grade LHR? People have reported different inductance readings from different meters. After getting the exact same model that Anders used, while I learned some things in using it, it really only got me into the ballpark. Once the car is running, beyond judging by how the car idles and drives, the only real way to dial it in is by accurately reading the AFR for the various conditions. Money would be better spent on that then an inductance meter. |
adolimpio |
Oct 28 2021, 02:37 PM
Art Group: Members Posts: 180 Joined: 10-March 10 From: Greenwood SC Member No.: 11,449 Region Association: South East States |
You really need an O2 meter to get it right, but if you just want to get close, I have a Wavetec and would be happy to adjust anyone's MPS to the specs published by Anders, or any values you specify. I did 3 at Okteenerfest with good results. Just pay the shipping.
emerygt350 |
Oct 28 2021, 02:56 PM
I am almost there... still a little lean on the plug tonight. Gave the inner screw another loosening turn, idle dropped again, brought it up with the idle screw. ECU knob has a very large effect as well but I am keeping it at the factory mark for the time being.
And as I said before, I have an AFR, I just don't want to drill my exhaust. |
BeatNavy |
Oct 28 2021, 03:17 PM
I was chasing my tail on inductance readings with my cheap meter. I finally got ahold of an unmolested 043 MPS and used that as my baseline by which to measure the other MPS's I had to adjust. You need to take Anders' absolute numbers with a grain of salt. The slope across the range is probably more relevant. You also need to use several inputs as clues about how you're running as applicable and available: O2 sensor (if you have one), dyno, butt dyno, plugs, exhaust smell, head temps, tailpipe, etc. etc.
If one does use an O2 sensor, I recommend running a "tee" vacuum hose off the MPS hose and attach it to a vacuum gauge in the cabin. That way you can see what vacuum you're actually drawing under what driving conditions. Many people are confused about what "part load" may mean (I think I was). Anyway, it's a good learning experience if you don't already know. |
emerygt350 |
Oct 29 2021, 06:50 AM
Yeah, as soon as I get it in a good spot I am going to record the inductance readings for future reference.
I reread everything pbanders had on operation of the MPS and all of the info Chris has given me and pulled it again this morning. 1) This time I started by loosening the inner screw all the way till it bottomed out on the outer screw. 2) I then adjusted the outer screw until I had the diaphragm range of motion that Chris suggests with his kit (movement stops a little before 7#). 3) I then adjusted the stop screw downwards until it just begins to move the diaphragm at 0#. Rinse and repeat a little on both 2 and 3. 4) I left the inner screw bottomed out and will tighten that alone at this point to taste (making it leaner if needed). Drove it to work. Runs great, feels a little richer. No bucking or strange partial throttle transitions. Will get it on the highway and check the plugs later. |
ChrisFoley |
Oct 29 2021, 09:05 AM
As another point of reference:
I just unscrewed an inner screw of a diaphragm which I believe was unchanged from factory. It went a little less than 3 full turns to the left before it locked against the outer screw. I normally recommend enrichment of 1 1/2 turns from stock. |
emerygt350 |
Oct 29 2021, 10:03 AM
Lo-Fi Version | Time is now: 4th May 2024 - 04:16 PM |
