Is there a source for this rubber vacuum "Y"? |
Posts in this area are restricted to the following format. If you have a general question, please post it in the Garage.
1. All new threads MUST be titled with a part number only. (i.e. 901.351.801.17)
2. Thread description should be an english description of the part. (i.e. Brake Dust Shields)
3. Replies to the thread are only restricted by pertinence. Some examples are original finish of the part (painted, cad plated, etc), common failures (cracking at the mount points), repair information or tips, pictures (stock or custom), upgrades, etc.
If you have any questions regarding the rules of this forum, please PM McMark.
jrmdir |
Nov 1 2021, 11:40 AM
Member Group: Members Posts: 224 Joined: 13-May 21 From: Central Ohio Member No.: 25,544 Region Association: Upper MidWest |
Connects the AAR to the plenum on my '73 1.7. Small branch feeds vacuum to the Decel Valve. PET shows something similar as 022-129-637 B and that seems to be available from several sources (see: http://www.914world.com/bbs2/index.php?showtopic=227136) But on that version the right angle of the larger tube won't work with how the AAR is situated relative to the plenum on the 1.7.
TIA for any suggestions. Ron |
eric9144 |
Nov 1 2021, 12:15 PM
Advanced Member Group: Members Posts: 2,734 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California |
(IMG:style_emoticons/default/beerchug.gif) Think this is what you're looking for? Shape of yours is a bit odd but...
https://914rubber.com/branch-piece-air-dist...with-fittings-1 |
eric9144 |
Nov 1 2021, 12:32 PM
Lo-Fi Version | Time is now: 18th May 2024 - 03:39 PM |
