1.7 air cleaner, Which air cleaner correct for my model |
bbrock |
Nov 2 2021, 04:18 PM
No, you have a 1.7. if it is a 2.0 they put 1.7 heads on it. The spark plug angle tells all. (IMG:style_emoticons/default/agree.gif) Maybe somebody thought putting a 2.0L FI on would boost power somehow just like they apparently thought cutting the bottom out of the air cleaner would. Maybe there is a big bore in there which would make a little more sense for the FI swap. Regardless, spark plug angles say NOT 2.0L heads and the case number and exchangers agree. |
windforfun |
Nov 13 2021, 05:00 PM
Senior Member Group: Members Posts: 1,835 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Here you go. Working in the engine well is so much easier now.
Attached thumbnail(s) |
emerygt350 |
Nov 13 2021, 05:41 PM
Advanced Member Group: Members Posts: 2,138 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
914werke |
Nov 13 2021, 09:40 PM
"I got blisters on me fingers" Group: Members Posts: 10,124 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Pull a valve cover & using a penlight & some contortions you should be able to make out the part # casting.
As has been already mentioned, who knows whats been done over the past decades. I did a 1.9L sometime ago using 2.0L heads FI & exhaust components, unless you dug into it you'd never know! |
Lo-Fi Version | Time is now: 7th June 2024 - 01:09 AM |
