Favorite motor oil, First oil change |
robkammer |
Nov 3 2021, 12:11 PM
Member Group: Members Posts: 179 Joined: 7-January 21 From: Vermilion Ohio Member No.: 25,049 Region Association: North East States |
Hey everyone: The BB is getting it's first oil change since it arrived. I'm thinking a good organic oil would be appropriate for this vintage motor with 121K on the clock.
The service records I have are not specific about what has been put in before. I use Syn in every other car but I think it might be overkill and make it leak even more. This should be fun! |
ClayPerrine |
Nov 3 2021, 12:16 PM
Life's been good to me so far..... Group: Admin Posts: 15,394 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Hey everyone: The BB is getting it's first oil change since it arrived. I'm thinking a good organic oil would be appropriate for this vintage motor with 121K on the clock. The service records I have are not specific about what has been put in before. I use Syn in every other car but I think it might be overkill and make it leak even more. This should be fun! Simple answer. Valvoline VR1. It is a high Zinc oil that is designed for older motors. There are others out there like Brad Penn, but the Valvoline is available at your FLAPS, and the others are normally only available at specialty stores. So it is easier to find. I suggest 20W50 for a stock air cooled motor. And don't buy a Fram rock stopper air filter. Buy a good one like Wix or Mann. Clay |
iankarr |
Nov 3 2021, 01:25 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,471 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
And prepare yourself for an onslaught of oil opinions. The distilled consensus from the engine gurus is that if you change your oil annually or at regular, reasonable mileage intervals, it doesn't really matter which brand you use, as long as the oil has generous ZDDP levels. I personally like VR1 for the reasons mentioned above. I also use the Joe Gibbs Driven DT50, which was developed specifically for air cooled engines. Mostly because I won a case of it at the NE gathering (IMG:style_emoticons/default/wink.gif) |
emerygt350 |
Nov 3 2021, 01:33 PM
Advanced Member Group: Members Posts: 2,067 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
I prefer a lighter weight synth like 5w40 mobile 1 euro blend. I find it takes the heat away better probably due to a larger volume of oil moving through (remember these are oil cooled). Synth also survives hot spots much better (critical temps in the 300s rather than the mid 200s). Thinner oil also gets to everywhere in the engine faster on cold starts and that is when the damage is done (thus the love of zddp, whether that benefit is real or not is also a huge area of debate).
That said, if you have a leaker, synth and thinner probably isn't for you. If I were to use thick dino, I would change it pretty frequently on an old air cooled engine, at least keep a close eye on it. |
JamesM |
Nov 3 2021, 02:28 PM
Senior Member Group: Members Posts: 1,888 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
I prefer a lighter weight synth like 5w40 mobile 1 euro blend. I find it takes the heat away better probably due to a larger volume of oil moving through (remember these are oil cooled). Synth also survives hot spots much better (critical temps in the 300s rather than the mid 200s). Thinner oil also gets to everywhere in the engine faster on cold starts and that is when the damage is done (thus the love of zddp, whether that benefit is real or not is also a huge area of debate). That said, if you have a leaker, synth and thinner probably isn't for you. If I were to use thick dino, I would change it pretty frequently on an old air cooled engine, at least keep a close eye on it. That could also be due to lower oil pressures from the thinner oil as well. At high oil pressure the oil cooler gets bypassed. I have always ran 20w50 but have considered running thinner oil for this reason (but i dont have an oil temp gauge atm so would have no idea if it made a difference) Personally I run Gibbs DT50, can only get that mail order though. Prior to that I ran VR1 racing as it was the only oil I could get locally with decent zinc numbers. Whatever you go with I would recommend it be fully synthetic due to having much better breakdown temps. Never ran Mobile 1 in a 914 but I was running M1 0W40 European Formula in my newer BMWs. I stopped when I realized the the engines ran a lot quieter with 0W40 Castrol (or Valvoline, or pretty much anything but Mobile 1), now I dont put Mobile 1 in anything anymore. Never really noticed to much difference between oils before that. |
Rand |
Nov 3 2021, 02:39 PM
Just be aware of zddp. This topic resurfaces, but looking back is always relevant for those who haven't seen it.
http://www.randbaldwin.com/index.php/914-and-oils/ |
emerygt350 |
Nov 3 2021, 03:22 PM
That could also be due to lower oil pressures from the thinner oil as well. Recently I have been thinking about that. Because the cut off is pressure based and relies on the oil pressure falling below ...i can't remember... before it goes to the cooler I guess you could run into an issue with extra hot oil not going to the cooler because the pressure would damage the cooler. That would mean less ability to pull heat of of the engine as it circulates. That was probably all determined on the old 30 weight dino too. I have always had luck with mobil 1 euro. Occasionally I try other brands but I keep coming back. You can't beat it for 24 dollars for 5 quarts at walmart. I spend the saved money on mobil 1 filters too. No clue if they are any better than any other but why not. |
StarBear |
Nov 3 2021, 03:30 PM
Senior Member Group: Members Posts: 1,845 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
Hey everyone: The BB is getting it's first oil change since it arrived. I'm thinking a good organic oil would be appropriate for this vintage motor with 121K on the clock. The service records I have are not specific about what has been put in before. I use Syn in every other car but I think it might be overkill and make it leak even more. This should be fun! Simple answer. Valvoline VR1. It is a high Zinc oil that is designed for older motors. There are others out there like Brad Penn, but the Valvoline is available at your FLAPS, and the others are normally only available at specialty stores. So it is easier to find. I suggest 20W50 for a stock air cooled motor. And don't buy a Fram rock stopper air filter. Buy a good one like Wix or Mann. Clay (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) with all he posted. |
bbrock |
Nov 3 2021, 04:03 PM
I've been thinking about this a lot as I'm about ready for the first oil change on my rebuilt engine (actually 3rd if you count the change following cam break-in and another after running 500 miles on break-in oil). I'm running VR1 now but interested in moving to synthetic. There are quite a few high zinc oils (both synthetic and conventional) out there now formulated for classic cars. VR1 is even available in synthetic form. There are only 2 I can get locally - conventional VR1 and Mobil 1 15W-50 (which is 1200 ppm phosphorous and 1300 ppm zinc). I'm not really a Mobil 1 fan but local availability is appealing.
But there are many other options mail order so my question is, what is the lightest oil you'd feel safe running in a Type 4 engine? I have read that tighter machining tolerances on engines have allow use of lighter oils. No idea if that is true, but Mobil 1 has high zinc formulations in 0W-40, 5W-40, and 15W-50. Synthetic VR1 is 20W-50. It's nice to have choices again. Here's a link to Mobil 1 oils with zinc and phosphorous specs: https://www.mobil.com/lubricants/-/media/pr...uide-rev-31.pdf |
windforfun |
Nov 3 2021, 04:39 PM
Senior Member Group: Members Posts: 1,771 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
20W50 from Porsche.
emerygt350 |
Nov 3 2021, 05:14 PM
I like the old rule "run the thinnest oil that gives you good pressure". I get 50 pounds at 2500 rpm running 5w40 hot and 15 pounds at idle hot. When it's less hot (not ripping through the hills or extended 70 mph on the highway) I get 20 at idle and 55-60 above 2500. More than enough pressure, I could probably go to 30 if I wanted more flow, but I think 40 is a good compromise and it is air-cooled and all
barnfind9141972 |
Nov 3 2021, 08:39 PM
Member Group: Members Posts: 100 Joined: 10-December 20 From: Rancho Mirage, CA Member No.: 24,976 Region Association: Southern California |
Question for everyone, I’m getting a 2258 built right now and live in Palm Desert so it’s warm everyday for the most part. What oil does everyone recommend for hotter climates or is it relatively the same thing? (IMG:style_emoticons/default/WTF.gif)
SKL1 |
Nov 3 2021, 09:13 PM
Senior Member Group: Members Posts: 1,597 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
What Clay said. I've been running the VR1 Valvoline 20-50 in both cars for a while now.
I don't usually drive them when it's over 100 and obviously not when it's 110+ and I've had no low oil pressure issues. |
GBX0073 |
Nov 3 2021, 10:28 PM
Member Group: Members Posts: 163 Joined: 21-December 20 From: Illinois Member No.: 25,007 Region Association: Upper MidWest |
VR1 ,I like that it can be found local in a store
With the thought process I can change more often if needed |
emerygt350 |
Nov 4 2021, 04:35 AM
Question for everyone, I’m getting a 2258 built right now and live in Palm Desert so it’s warm everyday for the most part. What oil does everyone recommend for hotter climates or is it relatively the same thing? (IMG:style_emoticons/default/WTF.gif) I would ask the builder too. The guys that built my 302 had specific tolerances they aim for and recommended an oil weight to match them. |
robkammer |
Nov 4 2021, 07:40 AM
Thanks everyone! I'm thinking the VR1 sounds right, 20W50 if I can find it locally. I plan on annual changes and I doubt I'll have more than 1000 miles a year on the car. I swear that I'll sell it before I put 20,000 on it as I NEVER want to inspect the strainer again.
Replacing the IMS in my 986 wan't as stressful as that damn strainer nut. Cheers! |
GregAmy |
Nov 4 2021, 08:15 AM
Advanced Member Group: Members Posts: 2,264 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
914_7T3 |
Nov 4 2021, 11:38 AM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,846 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
ZDDP for days! |
Superhawk996 |
Nov 4 2021, 12:44 PM
914 Guru Group: Members Posts: 5,726 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Spoke |
Nov 4 2021, 07:22 PM
Jerry Group: Members Posts: 6,972 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I'm thinking the VR1 sounds right, 20W50 if I can find it locally. I use VR1 (not the synthetic type) in both my 914 and 930. It's relatively inexpensive and readily available. Also there have been internet sales as well and I've purchased some from the net as well as local. |
Lo-Fi Version | Time is now: 19th April 2024 - 05:44 PM |
