‘74 1.8L L-Jetronic Cold Start Low Idle, Mystery solved! |
Van B |
Nov 7 2021, 04:01 PM
Senior Member Group: Members Posts: 1,582 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None |
Ok fellas, here’s the run down Aux Air Regulator (AAR) and Cold Start Valve (CSV)/injector both work fine. Many of you have also been keeping up with my high idle issue that we figured out.
But yet, when the car is cold, i.e. room temp, I don’t get the high idle I should on start-up. Instead she cranks a bit and then lumbers to life. Idle lopes around 700-800rpm and then smooths out as it warms. In all other aspects of operation, the engine seems to be pretty happy. Thoughts? Experience? (IMG:style_emoticons/default/confused24.gif) -Van See post #419 on page 14 for a synopsis of the outcome. |
emerygt350 |
Nov 7 2021, 04:13 PM
Advanced Member Group: Members Posts: 2,081 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Hmmm.... Are you sure about the aar? Just unplug it from the plenum while you cold start. See if that changes anything.
Low idle tends to be a rich condition or retarded timing. |
Lo-Fi Version | Time is now: 2nd May 2024 - 10:55 AM |
