‘74 1.8L L-Jetronic Cold Start Low Idle, Mystery solved! |
Van B |
Nov 7 2021, 04:01 PM
Senior Member Group: Members Posts: 1,582 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None |
Ok fellas, here’s the run down Aux Air Regulator (AAR) and Cold Start Valve (CSV)/injector both work fine. Many of you have also been keeping up with my high idle issue that we figured out.
But yet, when the car is cold, i.e. room temp, I don’t get the high idle I should on start-up. Instead she cranks a bit and then lumbers to life. Idle lopes around 700-800rpm and then smooths out as it warms. In all other aspects of operation, the engine seems to be pretty happy. Thoughts? Experience? (IMG:style_emoticons/default/confused24.gif) -Van See post #419 on page 14 for a synopsis of the outcome. |
Van B |
Nov 7 2021, 05:05 PM
So, I pulled the CSV/injector today and put some tape over the manifold. Kept the CSV connected and cranked the engine. It gave a nice cooling gasoline spritz all over the engine while I was cranking the engine, but once the car started, it was content with the work accomplished and went to sleep.
So, if that’s all it’s meant to do, it’s doing a great job. But if it was supposed to do more, something is telling it not to. Van |
Lo-Fi Version | Time is now: 2nd May 2024 - 03:26 PM |
