‘74 1.8L L-Jetronic Cold Start Low Idle, Mystery solved! |
Van B |
Nov 7 2021, 04:01 PM
Senior Member Group: Members Posts: 1,582 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None |
Ok fellas, here’s the run down Aux Air Regulator (AAR) and Cold Start Valve (CSV)/injector both work fine. Many of you have also been keeping up with my high idle issue that we figured out.
But yet, when the car is cold, i.e. room temp, I don’t get the high idle I should on start-up. Instead she cranks a bit and then lumbers to life. Idle lopes around 700-800rpm and then smooths out as it warms. In all other aspects of operation, the engine seems to be pretty happy. Thoughts? Experience? (IMG:style_emoticons/default/confused24.gif) -Van See post #419 on page 14 for a synopsis of the outcome. |
wonkipop |
Nov 11 2021, 05:34 PM
Advanced Member Group: Members Posts: 4,254 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
yes @emerygt350 , that would all work to duplicate.
what i will probably do at xmas is just unbolt the aav anyway and do the hose tests etc where i can manouvre the aav. i'll be giving it a good go over again to just see if i can make any difference. i think you can still get new ones. they put the same AAV on 924s. i can remember researching it and i seem to recall that i managed to source them. those aavs that went on L jets went on to be used on a lot of other cars for quite a long period afterwards. |
StarBear |
Nov 11 2021, 06:19 PM
Senior Member Group: Members Posts: 1,855 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
yes @emerygt350 , that would all work to duplicate. what i will probably do at xmas is just unbolt the aav anyway and do the hose tests etc where i can manouvre the aav. i'll be giving it a good go over again to just see if i can make any difference. i think you can still get new ones. they put the same AAV on 924s. i can remember researching it and i seem to recall that i managed to source them. those aavs that went on L jets went on to be used on a lot of other cars for quite a long period afterwards. My mechanic found a Volvo hose bend that fit perfectly. Pre-bent so doesn’t pinch. That alt test is much easier, for sure. |
Lo-Fi Version | Time is now: 2nd May 2024 - 06:20 PM |
