‘74 1.8L L-Jetronic Cold Start Low Idle, Mystery solved! |
Van B |
Nov 7 2021, 04:01 PM
Senior Member Group: Members Posts: 1,582 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None |
Ok fellas, here’s the run down Aux Air Regulator (AAR) and Cold Start Valve (CSV)/injector both work fine. Many of you have also been keeping up with my high idle issue that we figured out.
But yet, when the car is cold, i.e. room temp, I don’t get the high idle I should on start-up. Instead she cranks a bit and then lumbers to life. Idle lopes around 700-800rpm and then smooths out as it warms. In all other aspects of operation, the engine seems to be pretty happy. Thoughts? Experience? (IMG:style_emoticons/default/confused24.gif) -Van See post #419 on page 14 for a synopsis of the outcome. |
Van B |
Nov 11 2021, 07:22 PM
Trouble with this little project is a I get like one cold start a day lol. Now that I’ve got the decel valve sorted, I’m gonna pull that hose prior to start tomorrow.
I’m definitely not going to bet against emery, but I’m not convinced since I already took the AAR off, cleaned, and did a function check. |
Lo-Fi Version | Time is now: 2nd May 2024 - 07:39 PM |
