‘74 1.8L L-Jetronic Cold Start Low Idle, Mystery solved! |
Van B |
Nov 7 2021, 04:01 PM
Senior Member Group: Members Posts: 1,582 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None |
Ok fellas, here’s the run down Aux Air Regulator (AAR) and Cold Start Valve (CSV)/injector both work fine. Many of you have also been keeping up with my high idle issue that we figured out.
But yet, when the car is cold, i.e. room temp, I don’t get the high idle I should on start-up. Instead she cranks a bit and then lumbers to life. Idle lopes around 700-800rpm and then smooths out as it warms. In all other aspects of operation, the engine seems to be pretty happy. Thoughts? Experience? (IMG:style_emoticons/default/confused24.gif) -Van See post #419 on page 14 for a synopsis of the outcome. |
Van B |
Nov 12 2021, 05:44 PM
Found this on the YouTubes:
https://www.youtube.com/watch?v=FGEvf16nNQM This is exactly what my car is like on cold start. Continuing with the inference of my previous post, is there ANYONE with a 1.8L that actually gets a high idle from their car when starting from cold? https://youtu.be/FGEvf16nNQM |
StarBear |
Nov 12 2021, 06:34 PM
Senior Member Group: Members Posts: 1,855 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
Found this on the YouTubes: https://www.youtube.com/watch?v=FGEvf16nNQM This is exactly what my car is like on cold start. Continuing with the inference of my previous post, is there ANYONE with a 1.8L that actually gets a high idle from their car when starting from cold? https://youtu.be/FGEvf16nNQM Nope, but I like to set my idle a bit higher, at 950-1000 rpm so that might be masking it. Sealed up the connection downstream from the AAR to the air box as I couldn’t get a leak free seal. Two wraps of black electrical tape. This is a much- needed thread. Destined to be a classic for 2-port 1.8L cars. |
Lo-Fi Version | Time is now: 2nd May 2024 - 07:08 PM |
