‘74 1.8L L-Jetronic Cold Start Low Idle, Mystery solved! |
Van B |
Nov 7 2021, 04:01 PM
Senior Member Group: Members Posts: 1,582 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None |
Ok fellas, here’s the run down Aux Air Regulator (AAR) and Cold Start Valve (CSV)/injector both work fine. Many of you have also been keeping up with my high idle issue that we figured out.
But yet, when the car is cold, i.e. room temp, I don’t get the high idle I should on start-up. Instead she cranks a bit and then lumbers to life. Idle lopes around 700-800rpm and then smooths out as it warms. In all other aspects of operation, the engine seems to be pretty happy. Thoughts? Experience? (IMG:style_emoticons/default/confused24.gif) -Van See post #419 on page 14 for a synopsis of the outcome. |
StarBear |
Nov 14 2021, 11:01 AM
Senior Member Group: Members Posts: 1,855 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
Here's my Virgo Engineer testing this AM:
Tuneup 2 days ago. 49 degrees dwell; 7.5-8.0 BTDC (red mark on right side of V notch); spark plugs light gray coating - wire brushed and gap checked. Set car out on driveway for 20 min @ 41F, 72% humidity; light wind, light clouds. Deck lid open. 9:43 AM - cranked; 4-5 rumbles then steady at 1000 rpm (I tend to like my idle set a bit higher, and advance a tad more, than spec). 9:44 - 1100 rpm; steady 9:45 - 1100 rpm; steady 9:46 - 1000 rpm; steady 9:47 - 975 rpm; steady 9:48 - 1050 rpm; steady A little idle dip at 3-5 min, then back up. (The AAR closing?) 5 mi drive to hardware store; ~ 15-20 min. Warm start @ 900 rpm; steady 7 mi drive home and around the block; ~ 15 min. Shut off. 45F. Full warm start @ 1000 rpm; steady. Decel valve working fine (though still want to check it and adjust to 20 if needed) Looks like all fine here in NJ! (IMG:style_emoticons/default/driving.gif) Van B: I like where you're going with this.... (IMG:style_emoticons/default/smile.gif) |
emerygt350 |
Nov 14 2021, 11:15 AM
Advanced Member Group: Members Posts: 2,081 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
It was 30F this morning. Took almost 8 minutes of cruising before the aar called it good. I assume it's the same part.
Fwiw I stole the bellows off a 1.7 van engine laying around in a friend's garage.... Seems to work well, my engine runs super cool though. |
wonkipop |
Nov 14 2021, 02:38 PM
Advanced Member Group: Members Posts: 4,255 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
It was 30F this morning. Took almost 8 minutes of cruising before the aar called it good. I assume it's the same part. Fwiw I stole the bellows off a 1.7 van engine laying around in a friend's garage.... Seems to work well, my engine runs super cool though. to me that sounds right for an AAR. - would align with about how long my engine seems to be taking to get to something close to semi warmed up. the AAR is a different beast on the D jets. thanks @StarBear for the weather report in NJ. (IMG:style_emoticons/default/beerchug.gif) and countdown info. does sound like the AAR on yours dips out a little bit early too - but is in better shape than mine and not in such a hurry. pretty funny in the end. whole thing is a kind of cuckoo clock bit of krautrock technology in a good sort of way. everything is timed but not necessarily very much is reactive. |
Lo-Fi Version | Time is now: 2nd May 2024 - 09:01 PM |
