‘74 1.8L L-Jetronic Cold Start Low Idle, Mystery solved! |
Van B |
Nov 7 2021, 04:01 PM
Senior Member Group: Members Posts: 1,582 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None |
Ok fellas, here’s the run down Aux Air Regulator (AAR) and Cold Start Valve (CSV)/injector both work fine. Many of you have also been keeping up with my high idle issue that we figured out.
But yet, when the car is cold, i.e. room temp, I don’t get the high idle I should on start-up. Instead she cranks a bit and then lumbers to life. Idle lopes around 700-800rpm and then smooths out as it warms. In all other aspects of operation, the engine seems to be pretty happy. Thoughts? Experience? (IMG:style_emoticons/default/confused24.gif) -Van See post #419 on page 14 for a synopsis of the outcome. |
Van B |
Nov 14 2021, 08:00 AM
I'm using the forceps to see if the engine wants a richer mixture on cold start. If the forceps result in a higher cold start rpm, then my working theory will be that the engine is too lean on cold start. If the engine struggles even more with forceps on, then the AAR is not providing enough air.
We'll see... It could also result in not a damn thing lol.... |
wonkipop |
Nov 14 2021, 03:49 PM
Advanced Member Group: Members Posts: 4,253 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
I'm using the forceps to see if the engine wants a richer mixture on cold start. If the forceps result in a higher cold start rpm, then my working theory will be that the engine is too lean on cold start. If the engine struggles even more with forceps on, then the AAR is not providing enough air. We'll see... It could also result in not a damn thing lol.... i know what you are saying. be interested to see what you find. i'm kind of curious about the way everything is fine on mine for 2 minutes and then there is a problem for a short amount of time. i'll be asking mechanic at workshop about it today to see what he thinks now i can describe accurately the sequence. |
Lo-Fi Version | Time is now: 2nd May 2024 - 11:01 AM |
