‘74 1.8L L-Jetronic Cold Start Low Idle, Mystery solved! |
Van B |
Nov 7 2021, 04:01 PM
Senior Member Group: Members Posts: 1,582 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None |
Ok fellas, here’s the run down Aux Air Regulator (AAR) and Cold Start Valve (CSV)/injector both work fine. Many of you have also been keeping up with my high idle issue that we figured out.
But yet, when the car is cold, i.e. room temp, I don’t get the high idle I should on start-up. Instead she cranks a bit and then lumbers to life. Idle lopes around 700-800rpm and then smooths out as it warms. In all other aspects of operation, the engine seems to be pretty happy. Thoughts? Experience? (IMG:style_emoticons/default/confused24.gif) -Van See post #419 on page 14 for a synopsis of the outcome. |
Porschef |
Nov 15 2021, 10:13 AM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
I’m running Ljet on a 2056 with a 9550 cam
Cold start always requires a little bit of gas pedal, it doesn’t idle high and threatens to stall if i take my foot off. But cold start has improved greatly with the 123 distributor, and by the time I drive out of the neighborhood it is pretty much good I think I do recall others having similar issues with anything other than stock engines It runs fine otherwise I hesitate to add a cable/rod activated idle increase device… |
Lo-Fi Version | Time is now: 2nd May 2024 - 12:08 PM |
