‘74 1.8L L-Jetronic Cold Start Low Idle, Mystery solved! |
Van B |
Nov 7 2021, 04:01 PM
Senior Member Group: Members Posts: 1,582 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None |
Ok fellas, here’s the run down Aux Air Regulator (AAR) and Cold Start Valve (CSV)/injector both work fine. Many of you have also been keeping up with my high idle issue that we figured out.
But yet, when the car is cold, i.e. room temp, I don’t get the high idle I should on start-up. Instead she cranks a bit and then lumbers to life. Idle lopes around 700-800rpm and then smooths out as it warms. In all other aspects of operation, the engine seems to be pretty happy. Thoughts? Experience? (IMG:style_emoticons/default/confused24.gif) -Van See post #419 on page 14 for a synopsis of the outcome. |
wonkipop |
Nov 15 2021, 07:56 PM
Advanced Member Group: Members Posts: 4,253 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
@emery350gt (IMG:style_emoticons/default/smile.gif)
thats the point of L jet. its actually way simpler than D jet in most ways. its measuring air flow into the engine, what your throttle wants, before it gets to the throttle. its all downstream of the air flow meter. which is why it plain doesn't like air leaks. its pretty much what EFI became from then on for a long time. just got more sophisticated with more sensors and more real time feedback. L jet on a 914 is the proto system. its the adam or the eve, take your pick, of EFI that followed. thats why i bought my 1.8 30 years ago. i'm a geek. or i was one. too old to be a geek now, just a geezer. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 2nd May 2024 - 04:02 PM |
