‘74 1.8L L-Jetronic Cold Start Low Idle, Mystery solved! |
Van B |
Nov 7 2021, 04:01 PM
Senior Member Group: Members Posts: 1,582 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None |
Ok fellas, here’s the run down Aux Air Regulator (AAR) and Cold Start Valve (CSV)/injector both work fine. Many of you have also been keeping up with my high idle issue that we figured out.
But yet, when the car is cold, i.e. room temp, I don’t get the high idle I should on start-up. Instead she cranks a bit and then lumbers to life. Idle lopes around 700-800rpm and then smooths out as it warms. In all other aspects of operation, the engine seems to be pretty happy. Thoughts? Experience? (IMG:style_emoticons/default/confused24.gif) -Van See post #419 on page 14 for a synopsis of the outcome. |
wonkipop |
Nov 17 2021, 01:40 AM
Advanced Member Group: Members Posts: 4,253 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
the master has arrived ( @ClayPerrine ). good.
@Van B . re AAV. porsche used the AAV on 1.8s all the way through to the first series 944. in the 914 PET it has a 944 PN (944 606 103 00). i guess its a supersede part. i did a bit of searching - 944 AAV problems. this thread is good. someone figured out how to really clean them out. seafoam? got more gunk out of it than carb cleaner. he further shows how it might be possible to adjust it? https://rennlist.com/forums/924-931-944-951...tibility-2.html |
StarBear |
Nov 17 2021, 03:58 PM
Senior Member Group: Members Posts: 1,855 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
the master has arrived ( @ClayPerrine ). good. @Van B . re AAV. porsche used the AAV on 1.8s all the way through to the first series 944. in the 914 PET it has a 944 PN (944 606 103 00). i guess its a supersede part. i did a bit of searching - 944 AAV problems. this thread is good. someone figured out how to really clean them out. seafoam? got more gunk out of it than carb cleaner. he further shows how it might be possible to adjust it? https://rennlist.com/forums/924-931-944-951...tibility-2.html Tried it; reminded me of how much I dislike that site - WAY too many pop up ads and crap that only freezes up my computer. Never was able to check out the cleaning comment. (IMG:style_emoticons/default/confused24.gif) |
wonkipop |
Nov 17 2021, 04:21 PM
the master has arrived ( @ClayPerrine ). good. @Van B . re AAV. porsche used the AAV on 1.8s all the way through to the first series 944. in the 914 PET it has a 944 PN (944 606 103 00). i guess its a supersede part. i did a bit of searching - 944 AAV problems. this thread is good. someone figured out how to really clean them out. seafoam? got more gunk out of it than carb cleaner. he further shows how it might be possible to adjust it? https://rennlist.com/forums/924-931-944-951...tibility-2.html Tried it; reminded me of how much I dislike that site - WAY too many pop up ads and crap that only freezes up my computer. Never was able to check out the cleaning comment. (IMG:style_emoticons/default/confused24.gif) i have the same problem with that site,but can work it if i shut some ad pop ups. here are the screen grabs, its only one guy and two comments that are relevant. |
Lo-Fi Version | Time is now: 2nd May 2024 - 10:23 AM |
