Brakes, Stopping with M, A, or S |
Root_Werks |
Aug 2 2005, 09:59 AM
Village Idiot Group: Members Posts: 8,320 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
This is a good thread full of info. I like the reading! Thanks everyone for all the input. (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
Porsche Rescue |
Aug 2 2005, 10:09 AM
Eric, if late '72 (transition) were "one nipple", it is quite possible mine were from a commercial rebuilder and were rebuilt '72 cores installed on a '74. Given their fairly "fresh" look they probably were rebuilt somewhat recently.
Eric_Shea |
Aug 2 2005, 01:47 PM
Middle? (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
Eric_Shea |
Aug 2 2005, 01:49 PM
Jim,
That's what I was thinking too. There's no way a caliper would look that good today so it must be a rebuild. Let me know if you dig in and find otherwise. Thanks Dan. |
ArtechnikA |
Aug 2 2005, 01:56 PM
the words are the same either way... |
Eric_Shea |
Aug 2 2005, 02:28 PM
So the 914 is a "medium" motor car... we knew that (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
Eddie914 |
Aug 2 2005, 05:25 PM
Unregistered |
What are the dimensions of Carrera rotors?
Are there any larger rotors that car be bolted directly to the back of the hub? Will 968 rotors fit over the hub? Thanks Eddie |
johnmhudson111 |
Aug 2 2005, 07:11 PM
Member Group: Members Posts: 491 Joined: 29-November 04 From: Nesbit, MS Member No.: 3,191 |
Here is a question, how difficult would it be to fab up a bracket to relocate the /4 rear caplier so that it would be used as an e-brake only? On the surface it seems to be a workable solution. The only issue I can see is using/getting the correct spacers to widen the caplier for the thicker rotors. You guys know better than I, what do you think? (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) |
ArtechnikA |
Aug 2 2005, 07:52 PM
it is the application of the service brake that keeps the pads adjusted.
i don't think shrouding the disk with another caliper is a great idea, but i have seen this kind of thing done before -- but it was with a really teeny caliper and a BIG disk. |
Eric_Shea |
Aug 3 2005, 10:24 PM
24mm I really don't have any experience with any other rotors. |
johnmhudson111 |
Aug 4 2005, 07:00 AM
Is the concern you have with this method based on the impact the 2nd caplier would have on the rotors ability to disapate heat? It seems like it would be pretty simple to fab up a bracket to make this work but again, you guys have more experience in this department than I do. |
ArtechnikA |
Aug 4 2005, 07:09 AM
there are two concerns i stated.
1) the brake will not self-adjust. in theory, the pad should experience 'no' wear used as a parking brake; i know the dedicated parking brake in my 911 has received no adjustment in at least 2 years and doesn't seem to need any, so perhaps this is not a serious concern. 2) you reduce (by a fairly significant amount) the surface area of the disk exposed to free-stream air for cooling. is it bad enough to worry about? no one knows. i'd invest in some Tempilac heat-indicating paint and use *real* good brake fluid during the testing phase if you decide to go this route. 3) you've also increased unsprung weight by a nontrivial amount, but that may not be a horrible thing on a street car either. frankly, i think i like the small inboard disk and caliper concept a lot better. so i'm not saying it won't work, or it can't work. IMO the disadvantages outweigh the gains, but there is all kinds of room for experimentation and tinkering. so don't let me talk you out of it if you feel it's worth trying. just please be careful. |
davep |
Aug 4 2005, 10:06 AM
I saw an interesting parking brake on a 934. On the typical huge rear caliper were a pair of 'wings'. These wings pivoted off the bottom of the caliper, and carried a few square inches of friction material each. The tips of the wings were tied by the parking brake cable, and there was probably a spring in there to spread the wings when the brake was off. This car came fitted like that from the factory, raced at Le Mans, was in the Matsuda collection and is still factory original.
Eric_Shea |
Aug 4 2005, 01:37 PM
I say go with the strings and wings! (IMG:http://www.914world.com/bbs2/html/emoticons/w00t.gif)
ein 6er |
Aug 4 2005, 05:13 PM
Senior Member Group: Benefactors Posts: 1,115 Joined: 11-February 03 Member No.: 300 Region Association: None |
i believe they were 917 calipers. here are some pics on armando's site. |
ein 6er |
Aug 4 2005, 06:36 PM
here is a link to the mechanism.
Eric_Shea |
Aug 7 2005, 02:45 PM
Those look "fairly" easy to mfg.
Any of you machinest (Mueller) types care to take a stab? They could hang off a special spacer made for the M or Carrera caliper (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) |
Lo-Fi Version | Time is now: 16th May 2024 - 08:45 PM |
