Custom Exhaust Installation Struggle |
wysri9 |
Nov 14 2021, 05:54 AM
Member Group: Members Posts: 199 Joined: 23-August 13 From: Aberdeen, Scotland Member No.: 16,291 Region Association: England |
Hi guys
I am hoping to tap in to some experience with custom exhaust installations. I have what I believe to be a GT Racing "European Racing Headers" equal length exhaust system for my 2.23L Type IV build. The headers themselves are flanged and connect with short exhaust stubs which connect with the internal oval preparation in the cylinder heads with the copper ring seal. Two of these stubs sit between pushrod tubes (cylinders 1 and 4) and two sit to one side of the two pushrod tubes (2 and 3). I have two problems possibly related. Firstly I have interference between the stubs and a pushrod tube (exhaust in both cases) on cylinders 1 and 4. This has resulted in oil leaks from the tube seals due to the seal being pushed to one side. Investigating the leaks and trying to figure where I went wrong I now realise that there are two sorts of stubs - one where the connections on the stub are perpendicular to each other and one were there is a slight angle. Ill try to show that in a picture. So question is what am I doing wrong? Do I need to modify the stubs to give me the clearance I need, or does some trick of installation get around the issue? Do the "misaligned" stubs belong in certain positions? Any relevant comments very much welcomed! I have been (IMG:style_emoticons/default/headbang.gif) doing this for days now........its starting to hurt (IMG:style_emoticons/default/sad.gif) |
stownsen914 |
Nov 14 2021, 06:34 AM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
Any chance the stubs that are clocked, are that way to avoid the interference with the pushrod tubes? Look at the header primaries to see if any of flanges are clocked to match the clocked stub tubes.
It's also possible the clocking of the flanges is a fabrication error, and that the interference with the pushrod tubes is a design mistake. That would seem a bit odd though. Is GT Racing still selling these? Give them a call and ask about the clocking. I might be able to get comfortable with lightly dimpling the pushrod tubes if it gets rid of the interference, but the clocking would be tougher if the header flanges don't also have the clocking. |
ChrisFoley |
Nov 14 2021, 01:16 PM
I am Tangerine Racing Group: Members Posts: 7,926 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
The exhaust studs are not inline with the axis of the exhaust port on one port of each head.
wysri9 |
Nov 15 2021, 04:51 AM
Chris
Now that is a VERY useful fact! Who would have thought that........ Many thanks. Now I know where to start looking (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/beerchug.gif) |
AZBanks |
Nov 15 2021, 10:26 AM
Senior Member Group: Members Posts: 1,063 Joined: 7-December 05 From: New River, AZ Member No.: 5,245 Region Association: Southwest Region |
I have that exhaust on my car. I can get some pictures later today.
wysri9 |
Nov 16 2021, 03:35 AM
I have that exhaust on my car. I can get some pictures later today. More pics would be very helpful - especially where the stubs go through between the pushrod tubes. How much clearance is there? Can the stubs be installed with the tubes in place? really appreciate the help! (IMG:style_emoticons/default/beerchug.gif) |
rfinegan |
Nov 16 2021, 07:39 AM
Senior Member Group: Members Posts: 973 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
As many have mentioned, cylinders 1 and 4 stubs are dimpled to clear the push rod tubes. CFR /Tangerine has Stubs and small diameter push rod tubes to help with this. If they touch they will leak. Dimple the stubs or push rod tubs as needed for clearance
JamesM |
Nov 16 2021, 05:43 PM
Senior Member Group: Members Posts: 1,900 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
I have the same (or at least similar) euro race header setup. It looks like they have improved the quality a bit since I bought mine 10+ years ago. I didn't have any issues with clearing the pushrod tubes on the two motors I have run them on, but it looks like your stubs may be a little beefier? Hard to tell. Are your pushrods stock?
I do remember that the install was very particular about what stub pipe went where, all 4 are not identical, as well as their orientation (they wont work if rotated 180 degrees) may just be a bit of a puzzle to get everything in correctly. The 2nd motor I had mine on I did have to wind up drilling the holes in the stubs slightly larger to accommodate exhaust studs that were not perfectly straight. Biggest issue I have had with the system the entire time I have owned it is keeping it sealed up at the collector. I after 10+ years though I have given up in that battle and just ordered a setup from @ChrisFoley a few months ago. Worked with one of his setups on my buddies car and the construction had MUCH tighter tolerances at the slip joints. Still a few months out on delivery but interested to see how the tri-Y setup works with the engine vs the 4-1 collector. |
ChrisFoley |
Nov 17 2021, 06:48 AM
I think those stubs might be older, not newer. I've seen a set with that heavy cast section once before. They were welded up using a set of factory stubs cut from heat exchangers. The later ones are made by squishing a heavy wall tube and welding on tubular ears.
The ones made with factory stubs will clear the pushrod tubes when they're positioned as designed. |
VaccaRabite |
Nov 17 2021, 09:02 AM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Did you change the color for your headers? The Eurorace headers I had looked a little different. There was another company selling European racing headers that were made improperly, but that was an issue with one of the primary pipes, not the stubs.
I will say that I fought with leaks with my Eurorace system that I never was able to get right until I ditched them and went back to SSI exchangers. I never got the slip fit collector to fit right and always had a leak there. I got it close, and could keep it sealed for a bit with hi-temp RTV, but that was always a short term fix. With the turbo muffler, it was also LOUD. Sounded mean, but would leave your ears ringing after even a short drive. Zach |
Robarabian |
Nov 17 2021, 09:58 AM
914 A Roo Group: Members Posts: 592 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California |
The set I bought came with some instructions. You have to match each stub with each port. I numbered each one of them so easier to track them into the right ports when removing. Stamp or etch them with an engraver. IT takes some time to figure it all out unfortunately.
VaccaRabite |
Nov 17 2021, 10:17 AM
The set I bought came with some instructions. You have to match each stub with each port. I numbered each one of them so easier to track them into the right ports when removing. Stamp or etch them with an engraver. IT takes some time to figure it all out unfortunately. Yeah I remember doing that too. There is only one they they fit to be correct. Zach |
JamesM |
Nov 17 2021, 10:20 AM
I think those stubs might be older, not newer. I've seen a set with that heavy cast section once before. They were welded up using a set of factory stubs cut from heat exchangers. The later ones are made by squishing a heavy wall tube and welding on tubular ears. The ones made with factory stubs will clear the pushrod tubes when they're positioned as designed. Mine are the newer ones then as that is what I have, squished tube with bits welded on for mounting. Did you change the color for your headers? The Eurorace headers I had looked a little different. There was another company selling European racing headers that were made improperly, but that was an issue with one of the primary pipes, not the stubs. I will say that I fought with leaks with my Eurorace system that I never was able to get right until I ditched them and went back to SSI exchangers. I never got the slip fit collector to fit right and always had a leak there. I got it close, and could keep it sealed for a bit with hi-temp RTV, but that was always a short term fix. With the turbo muffler, it was also LOUD. Sounded mean, but would leave your ears ringing after even a short drive. Zach I had mine jet-hot coated to help with the melting clutch cables and they wound up looking just like that. Same issues though with they leaks being at the primaries where they slip fit into the collector, and yeah, one of the primaries seems like its about an inch to short. Tried a tailpipe expander to make it tighter, then high temp RTV, and most recently curing exhaust sealant and nothing seems to keep it sealed for long. Been just dealing with it as I only use the car for autox, but still, cant wait for the Tangerine setup to get here (IMG:style_emoticons/default/aktion035.gif) |
VaccaRabite |
Nov 18 2021, 07:26 AM
I had mine jet-hot coated to help with the melting clutch cables and they wound up looking just like that. Same issues though with they leaks being at the primaries where they slip fit into the collector, and yeah, one of the primaries seems like its about an inch to short. Tried a tailpipe expander to make it tighter, then high temp RTV, and most recently curing exhaust sealant and nothing seems to keep it sealed for long. Been just dealing with it as I only use the car for autox, but still, cant wait for the Tangerine setup to get here (IMG:style_emoticons/default/aktion035.gif) Your journey sounds exactly like mine. I also had mine ceramic coated (black though - that stuff is magic). The black ceramic had the pipes SO MUCH COOLER then the SSI exchangers. And yeah, I had the primaries bumped with an expander to try and get them to seal better to the collector, hi-temp RTV, exhaust sealant. NOTHING worked there and I sold the whole setup. I was going to cut off the turbo muffler and weld on something else to try and tame some of the noise, but I ended up just selling the whole mess and buying another set of SSIs. If y'all can't tell, I'm NOT a fan of the EuroRace headers. Buy headers from Chris or use SSI exchangers and a good muffler. These cheaper headers AREN'T cheaper. Not in the long run. Zach |
wysri9 |
Nov 23 2021, 12:20 AM
Guys
Many thanks to everyone for the feedback. I am stuck with this exhaust for the time being so will have to live with the collector issue. I have however decided that the stubs are just wrong. They interfere way too much with the pushrod tubes on 1 and 4. Joel at GT Racing has been fantastic and a new set of ceramic coated stubs are headed my way. That together with machined pushrod tubes will hopefully fix this issue. Now to go look for some super sealant that will sort the collector out...... Thanks again (IMG:style_emoticons/default/beerchug.gif) |
rfinegan |
Nov 23 2021, 05:45 AM
IF it helps, I have a set of stubs on the world here:
http://www.914world.com/bbs2/index.php?sho...p;hl=stub+pipes |
Lo-Fi Version | Time is now: 19th May 2024 - 03:55 PM |
