Turn signal indicator light, Only blinks once ... |
Chaznaster |
Nov 14 2021, 05:45 PM
Member Group: Members Posts: 288 Joined: 22-November 15 From: Concord, MA Member No.: 19,389 Region Association: North East States |
Hi. I have been trying to troubleshoot the turn signal indicator light - the one on the speedo. It's a '74 so only one light that is supposed to blink regardless of the chosen direction. It is not worked since I have the car. The signals themselves and the hazards work fine.
Recently, I went through and replaced the dashboard bulbs and got nearly everything working. Not the turn signal, however. Interestingly, when I disconnect and connect the battery, then switch either the lever on the steering column or the hazards, the light comes on once (yay!) but then refuses to come on again (awww). My first thought is the hazard relay (the square one on the back of the fuse panel) might be bad. Before trying to replace it (I have read that the new ones are problematic), does anyone have any other suggestions? If not, what is the most reliable source for that relay these days?? Thank you. |
dirk2056 |
Nov 14 2021, 05:49 PM
Member Group: Members Posts: 92 Joined: 31-July 17 From: cincinnati/Eastside Member No.: 21,304 Region Association: Middle East |
Hi. I have been trying to troubleshoot the turn signal indicator light - the one on the speedo. It's a '74 so only one light that is supposed to blink regardless of the chosen direction. It is not worked since I have the car. The signals themselves and the hazards work fine. Recently, I went through and replaced the dashboard bulbs and got nearly everything working. Not the turn signal, however. Interestingly, when I disconnect and connect the battery, then switch either the lever on the steering column or the hazards, the light comes on once (yay!) but then refuses to come on again (awww). My first thought is the hazard relay (the square one on the back of the fuse panel) might be bad. Before trying to replace it (I have read that the new ones are problematic), does anyone have any other suggestions? If not, what is the most reliable source for that relay these days?? Thank you. (IMG:style_emoticons/default/dry.gif) Did you change to LED lamps if so need to change relay |
Chaznaster |
Nov 14 2021, 07:52 PM
I am running an LED in the dash indicator but filament bulbs in the signals themselves.
I read that with LEDs in the signals there is not enough current to trip the indicator bulb secondary coil and light it. I had not understood the dash LED had the same impact - as it is just a bulb to ground with no logic. Is a different flasher needed in this case? |
Jim C |
Nov 15 2021, 08:28 AM
Member Group: Members Posts: 189 Joined: 11-July 19 From: Texas Member No.: 23,294 Region Association: Southwest Region |
I started having the same problem in my '76 which seemed to coincide with driving in a heavy rain. That was months ago so anything should have dried by now, plus the TS never stopped working. I can hear the relay ticking, but no indicator flash in tach after the first one. Research said the relay may be bad so I bought an aftermarket replacement and plugged it in. Upon turning the key indicator began flashing without have turn signals activated, brake warning light began flashing, as did generator light! (IMG:style_emoticons/default/confused24.gif)
Spoke |
Nov 15 2021, 11:30 AM
Jerry Group: Members Posts: 6,972 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
the light comes on once (yay!) but then refuses to come on again (awww). This is a common issue with the old OEM flashers. The secondary coil which powers the tach indicator loses efficiency over time and may flash once or twice then stop. There is an LED-compatible flasher available EP26 that is pin-compatible with the 914 flasher. It can drive standard bulbs or LEDs. The C2 pin on the EP26 out of the box isn't connected to anything. I modify them to put out 12V on C2 when flashing. The flashing of the tach indicator is not affected by the type of bulb used in the tach. LED or bulb can be used. |
GregAmy |
Nov 15 2021, 12:05 PM
Advanced Member Group: Members Posts: 2,264 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
2/3 of the way down the page. If you feel motivated, he also links to instructions on modifying one yourself (I bought one from him). https://www.spokeworksled.com/914-led-solutions?page=2 |
Chaznaster |
Nov 15 2021, 02:07 PM
Thanks Spoke and GregAmy. This is really helpful. It's great to be able to connect with folks who know so much about 914s! (IMG:style_emoticons/default/pray.gif)
I like to fiddle so plan to brave the modification myself. But for a future update to my lighting, I'll be headed over to spokeworks ... |
Jim C |
Nov 15 2021, 02:50 PM
Any insight on my problem above? I am using incandescent not LED bulbs.
Chaznaster |
Nov 15 2021, 03:00 PM
Any insight on my problem above? I am using incandescent not LED bulbs. It sounds like lots of people are having trouble with new, replacement relays. Likely due to quality control(?). Like you, I am running regular bulbs in the signals themselves and plan to try the modified EP26 option, which I understand will work for LEDs or filament bulbs. |
Chaznaster |
Nov 15 2021, 03:04 PM
the light comes on once (yay!) but then refuses to come on again (awww). This is a common issue with the old OEM flashers. The secondary coil which powers the tach indicator loses efficiency over time and may flash once or twice then stop. There is an LED-compatible flasher available EP26 that is pin-compatible with the 914 flasher. It can drive standard bulbs or LEDs. The C2 pin on the EP26 out of the box isn't connected to anything. I modify them to put out 12V on C2 when flashing. The flashing of the tach indicator is not affected by the type of bulb used in the tach. LED or bulb can be used. I was looking at the wiring diagrams and wonder whether the parking brake light works with the modified EP26 setup. Does it bypass the flasher circuit as in the OEM unit? And/or does it cause the turn signal indicator to light up as well? I am guessing there is only one coil in the EP26?! |
Chaznaster |
Nov 15 2021, 06:37 PM
the light comes on once (yay!) but then refuses to come on again (awww). This is a common issue with the old OEM flashers. The secondary coil which powers the tach indicator loses efficiency over time and may flash once or twice then stop. There is an LED-compatible flasher available EP26 that is pin-compatible with the 914 flasher. It can drive standard bulbs or LEDs. The C2 pin on the EP26 out of the box isn't connected to anything. I modify them to put out 12V on C2 when flashing. The flashing of the tach indicator is not affected by the type of bulb used in the tach. LED or bulb can be used. I was looking at the wiring diagrams and wonder whether the parking brake light works with the modified EP26 setup. Does it bypass the flasher circuit as in the OEM unit? And/or does it cause the turn signal indicator to light up as well? I am guessing there is only one coil in the EP26?! Hang on. I just noticed that parking brake light is tied to the primary relay in the flasher, which always blinks when a load is across it. So no change there. Still wondering if the C output only flashes the turn signal indicator when the turn signals or hazards are triggered, but not when the parking brake light is on ... |
Jim C |
Nov 16 2021, 08:36 AM
Chaznaster, let me know if that relay fixes the problem please.
DRPHIL914 |
Nov 16 2021, 10:03 AM
Dr. Phil Group: Members Posts: 5,758 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
ClayPerrine |
Nov 16 2021, 12:27 PM
Life's been good to me so far..... Group: Admin Posts: 15,394 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Chaznaster, let me know if that relay fixes the problem please. yes please do, i have this issue as well, but only on right side not left, and its just the indicator , the side flasher flashes just fine. Usually if it is only one side, it is a turn signal bulb is out. That is supposed to be an indicator of a bad bulb. Clay |
Chaznaster |
Nov 16 2021, 08:40 PM
Spoke |
Nov 17 2021, 05:31 AM
the light comes on once (yay!) but then refuses to come on again (awww). This is a common issue with the old OEM flashers. The secondary coil which powers the tach indicator loses efficiency over time and may flash once or twice then stop. There is an LED-compatible flasher available EP26 that is pin-compatible with the 914 flasher. It can drive standard bulbs or LEDs. The C2 pin on the EP26 out of the box isn't connected to anything. I modify them to put out 12V on C2 when flashing. The flashing of the tach indicator is not affected by the type of bulb used in the tach. LED or bulb can be used. I was looking at the wiring diagrams and wonder whether the parking brake light works with the modified EP26 setup. Does it bypass the flasher circuit as in the OEM unit? And/or does it cause the turn signal indicator to light up as well? I am guessing there is only one coil in the EP26?! The flasher system on the 914 is independent of the running lights. The only place they intersect is on the 1157 type bulbs which have 2 filaments, one for the running lights and one for the flasher system. The EP26 will work exactly like the OEM flasher in most ways. They both have low current flashing thresholds so it will flash when the ebrake is pulled or when driving LED turnsignals. The OEM secondary coil shown below is designed to light the tach indicator when flashing as long as two 1157 type bulbs are being lit. This is a safety feature if one turnsignal bulb is burned out; The signals will flash but the tach indicator will not to alert the driver of the bulb failure. EP26 doesn't have the secondary coil and pin C2 which goes to the tach indicator is open. I run a wire to connect C2 to 12V when flashing and open when not flashing just like the OEM. If you want to do this mod yourself you can pick up an EP26 at your FLAPS and add the wire. I show on my website where to make the connection. With EP26, the tach indicator will flash when you pull the ebrake since C2 will power the tach indicator anytime the unit is flashing. If you do buy an EP26, make sure it says LED-Compatible as EP26 is a re-used number from a Jeep and some of those units are still around and will not work with LEDs. Attached image(s) |
Chaznaster |
Dec 3 2021, 06:34 PM
UPDATE: IT WORKED (IMG:style_emoticons/default/laugh.gif)
Following @Spoke 's advice, I bought an LED-ready EP26 (pic) and modified it (pic) and now my turn signal indicator (in the tach) flashes with the turn signals themselves. This is the first time since I own the car. It also blinks when the hazard lights are blinking, but that's a small price to pay for getting things working. Now I won't drive for miles with the signal on accidentally (it does not turn itself off automatically after a turn but that is a different job for a different day) ... Thanks Spoke!! FYI @jim c and @drphil914 |
Krieger |
Dec 3 2021, 06:51 PM
Advanced Member Group: Members Posts: 4,694 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Chaznaster, let me know if that relay fixes the problem please. yes please do, i have this issue as well, but only on right side not left, and its just the indicator , the side flasher flashes just fine. Usually if it is only one side, it is a turn signal bulb is out. That is supposed to be an indicator of a bad bulb. Clay Thanks @ClayPerrine! I've had this problem for a few years, but never got to it. So two working bulbs on the dash will make one of them flash when activated? |
ClayPerrine |
Dec 4 2021, 10:51 AM
Chaznaster, let me know if that relay fixes the problem please. yes please do, i have this issue as well, but only on right side not left, and its just the indicator , the side flasher flashes just fine. Usually if it is only one side, it is a turn signal bulb is out. That is supposed to be an indicator of a bad bulb. Clay Thanks @ClayPerrine! I've had this problem for a few years, but never got to it. So two working bulbs on the dash will make one of them flash when activated? If you have a turn signal bulb out on either the front or rear the indicator light for that side should flash once and then they will both start flashing dimly. The other side will work correctly. Hope that helps. Clay |
DRPHIL914 |
Dec 5 2021, 05:52 AM
@Chaznaster
excellent! thanks for the update. i will have to check this out and see if i can make the same correction. |
Lo-Fi Version | Time is now: 20th April 2024 - 01:00 AM |
