Turn signal indicator light, Only blinks once ... |
Chaznaster |
Nov 14 2021, 05:45 PM
Member Group: Members Posts: 297 Joined: 22-November 15 From: Concord, MA Member No.: 19,389 Region Association: North East States |
Hi. I have been trying to troubleshoot the turn signal indicator light - the one on the speedo. It's a '74 so only one light that is supposed to blink regardless of the chosen direction. It is not worked since I have the car. The signals themselves and the hazards work fine.
Recently, I went through and replaced the dashboard bulbs and got nearly everything working. Not the turn signal, however. Interestingly, when I disconnect and connect the battery, then switch either the lever on the steering column or the hazards, the light comes on once (yay!) but then refuses to come on again (awww). My first thought is the hazard relay (the square one on the back of the fuse panel) might be bad. Before trying to replace it (I have read that the new ones are problematic), does anyone have any other suggestions? If not, what is the most reliable source for that relay these days?? Thank you. |
Chaznaster |
Nov 14 2021, 07:52 PM
I am running an LED in the dash indicator but filament bulbs in the signals themselves.
I read that with LEDs in the signals there is not enough current to trip the indicator bulb secondary coil and light it. I had not understood the dash LED had the same impact - as it is just a bulb to ground with no logic. Is a different flasher needed in this case? |
Lo-Fi Version | Time is now: 17th May 2024 - 02:45 PM |
