Turn signal indicator light, Only blinks once ... |
Chaznaster |
Nov 14 2021, 05:45 PM
Member Group: Members Posts: 297 Joined: 22-November 15 From: Concord, MA Member No.: 19,389 Region Association: North East States |
Hi. I have been trying to troubleshoot the turn signal indicator light - the one on the speedo. It's a '74 so only one light that is supposed to blink regardless of the chosen direction. It is not worked since I have the car. The signals themselves and the hazards work fine.
Recently, I went through and replaced the dashboard bulbs and got nearly everything working. Not the turn signal, however. Interestingly, when I disconnect and connect the battery, then switch either the lever on the steering column or the hazards, the light comes on once (yay!) but then refuses to come on again (awww). My first thought is the hazard relay (the square one on the back of the fuse panel) might be bad. Before trying to replace it (I have read that the new ones are problematic), does anyone have any other suggestions? If not, what is the most reliable source for that relay these days?? Thank you. |
Jim C |
Nov 15 2021, 02:50 PM
Member Group: Members Posts: 190 Joined: 11-July 19 From: Texas Member No.: 23,294 Region Association: Southwest Region |
Any insight on my problem above? I am using incandescent not LED bulbs.
Chaznaster |
Nov 15 2021, 03:00 PM
Any insight on my problem above? I am using incandescent not LED bulbs. It sounds like lots of people are having trouble with new, replacement relays. Likely due to quality control(?). Like you, I am running regular bulbs in the signals themselves and plan to try the modified EP26 option, which I understand will work for LEDs or filament bulbs. |
Lo-Fi Version | Time is now: 17th May 2024 - 04:12 PM |
