Small Rotor to Hub Screw Size, Need size |
jim_hoyland |
Nov 15 2021, 05:05 PM
Get that VIN ? Group: Members Posts: 9,301 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I need those little screws that attach the rotor to the hub so I can hold the rotor still while reattaching the calipers.
What size is are those little screws ? Attached image(s) |
914e |
Nov 15 2021, 05:45 PM
Member Group: Members Posts: 496 Joined: 21-February 20 From: Arizona Member No.: 23,951 Region Association: Southwest Region |
I think they are M6x12
Maltese Falcon |
Nov 15 2021, 09:02 PM
Advanced Member Group: Members Posts: 4,645 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
jim_hoyland |
Nov 15 2021, 09:18 PM
I need those little screws that attach the rotor to the hub so I can hold the rotor still while reattaching the calipers. What size is are those little screws ? Thread pitch should be; 6mm x 1.0mm Thanks… (IMG:style_emoticons/default/beer.gif) |
914e |
Nov 16 2021, 09:16 AM
I need those little screws that attach the rotor to the hub so I can hold the rotor still while reattaching the calipers. What size is are those little screws ? Thread pitch should be; 6mm x 1.0mm Is there different pitches for metric machine screws? |
ClayPerrine |
Nov 16 2021, 12:24 PM
Life's been good to me so far..... Group: Admin Posts: 15,465 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I need those little screws that attach the rotor to the hub so I can hold the rotor still while reattaching the calipers. What size is are those little screws ? Thread pitch should be; 6mm x 1.0mm Is there different pitches for metric machine screws? No. But it is a M6x1.0 screw. With the tapered head, you will probably only find allen head screws in your local hardware store. If you want to be picky, go to your P car parts place. They can get an original screw. |
jim_hoyland |
Nov 16 2021, 04:55 PM
I need those little screws that attach the rotor to the hub so I can hold the rotor still while reattaching the calipers. What size is are those little screws ? Thread pitch should be; 6mm x 1.0mm Is there different pitches for metric machine screws? No. But it is a M6x1.0 screw. With the tapered head, you will probably only find allen head screws in your local hardware store. If you want to be picky, go to your P car parts place. They can get an original screw. Your rightt( Ace Hardware only has 4mm Allen head screws. They will do what I need… Attached thumbnail(s) |
914Sixer |
Nov 16 2021, 09:18 PM
I use the SS screws that hold the mirrors or the door catches.
ClayPerrine |
Nov 17 2021, 08:05 AM
I need those little screws that attach the rotor to the hub so I can hold the rotor still while reattaching the calipers. What size is are those little screws ? Thread pitch should be; 6mm x 1.0mm Is there different pitches for metric machine screws? No. But it is a M6x1.0 screw. With the tapered head, you will probably only find allen head screws in your local hardware store. If you want to be picky, go to your P car parts place. They can get an original screw. Your rightt( Ace Hardware only has 4mm Allen head screws. They will do what I need… Exactly the ones I use. Ace hardware... My local bolt bin. If I don't have it in the garage, Ace is only a mile away. They know me by name there and greet me like an old friend. And they have an impressive collection of metric bolts and nuts. Ace is the place. Clay |
PatMc |
Nov 18 2021, 07:15 AM
Member Group: Members Posts: 120 Joined: 27-June 21 From: Long Beach Member No.: 25,669 Region Association: None |
Those screws serve no purpose one the lugs are torqued...
Just use a couple lug nuts to hold the rotor snug to the hub while adjusting the calipers, then pull them off and install the wheel. |
ClayPerrine |
Nov 18 2021, 09:13 AM
Those screws serve no purpose one the lugs are torqued... Just use a couple lug nuts to hold the rotor snug to the hub while adjusting the calipers, then pull them off and install the wheel. My father was an automotive engineer. His favorite saying was "Everything costs money, so engineers don't put parts on cars for the fun of it." That 10 cent screw over 100k cars adds up as profit lost for the manufacturer. So it definitely has a purpose, even if you can't see it. Clay |
Shivers |
Nov 18 2021, 09:39 AM
Senior Member Group: Members Posts: 2,378 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
I was told the screws help prevent torqueing the lug nuts with the brake disc off centered. I would think they would keep crud from getting between the hub and rotor changing a rear flat, potentially putting the wheel off.
BK911 |
Nov 18 2021, 05:58 PM
Senior Member Group: Members Posts: 672 Joined: 19-February 04 From: Rocky Top, TN Member No.: 1,674 Region Association: None |
I removed mine for reduction in unsprung rotational weight.
Saved almost 0.02 seconds off my fastest time to work. |
Lo-Fi Version | Time is now: 17th May 2024 - 03:54 PM |
