Dyno day, Now with figures!!! |
emerygt350 |
Nov 20 2021, 02:32 PM
Advanced Member Group: Members Posts: 2,081 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Just got back from the Dyno. We were able to tune the mps reasonably well. Still have a little leanness at wot and lower rpms and richness at wot at high rpms but overall pretty smooth. Waiting to get the figures from the shop. If I remember right it was 77 horsepower and 105 lbs of torque at the wheels. I am running big 225/50r16s so I suspect I would pick up some more with lighter stock rims and tires....
I will post the graphs as soon as I get them. |
Van B |
Nov 22 2021, 09:17 AM
Senior Member Group: Members Posts: 1,582 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None |
doesn't the 123 ignition let you create a custom ignition map; as in being able to advance at high RPM without being forced to advance across the whole curve?
I'm struggling to get my head around how advancing further causes increased richness. Unless it was so much advance that it was igniting prior to sufficient compression was reached to achieve a full burn. |
emerygt350 |
Nov 22 2021, 09:32 AM
doesn't the 123 ignition let you create a custom ignition map; as in being able to advance at high RPM without being forced to advance across the whole curve? I'm struggling to get my head around how advancing further causes increased richness. Unless it was so much advance that it was igniting prior to sufficient compression was reached to achieve a full burn. I think that is exactly what happened. And I have the non-bluetooth 123 so I believe I only have the built in mapping to work with. |
Lo-Fi Version | Time is now: 3rd May 2024 - 04:40 AM |
