Automatic Transmission, What is the best automatic transmission to put in a 914 1.7 |
JCP914 |
Nov 21 2021, 07:17 PM
Newbie Group: Members Posts: 3 Joined: 21-November 21 From: Indianapolis Member No.: 26,096 Region Association: None |
I am an amputee, I just purchased a 1972 914 and I need to convert it to an automatic. What is the best automatic and share how it can be done and where. I live in Indy.
ejm |
Nov 22 2021, 12:51 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,690 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
While a /4 sporto would be cool there's lots to consider. A sporto box would likely be sourced from a 911 and would need the ring gear flipped. You also need to find a vacuum tank and servo, the special shifter with the electrical contacts and maybe a fluid reservoir since the /6 used the engine oil tank. You'd need to figure out how to circulate oil for the convertor. The /6 used a pump driven off the end of the camshaft but a pump was never developed for a 914/4. You may be able to use something like the double pump from a VW autostick but will likely run into clearance problems with the engine support bar like you do with a dry sump pump. A few of the reasons why I don't think we've ever seen a /4 converted to sportomatic. A full auto from an inline engine front wheel drive VW/Audi is much easier since everything is in the box.
mgp4591 |
Nov 22 2021, 03:06 PM
914 Guru Group: Members Posts: 5,368 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
While a /4 sporto would be cool there's lots to consider. A sporto box would likely be sourced from a 911 and would need the ring gear flipped. You also need to find a vacuum tank and servo, the special shifter with the electrical contacts and maybe a fluid reservoir since the /6 used the engine oil tank. You'd need to figure out how to circulate oil for the convertor. The /6 used a pump driven off the end of the camshaft but a pump was never developed for a 914/4. You may be able to use something like the double pump from a VW autostick but will likely run into clearance problems with the engine support bar like you do with a dry sump pump. A few of the reasons why I don't think we've ever seen a /4 converted to sportomatic. A full auto from an inline engine front wheel drive VW/Audi is much easier since everything is in the box. 1.8T from an A4 automatic... Paging Andrew Dalen... (IMG:style_emoticons/default/driving.gif) |
ValcoOscar |
Nov 22 2021, 03:26 PM
Garage Life Group: Members Posts: 2,382 Joined: 19-November 13 From: SoCal Member No.: 16,669 Region Association: Southern California |
While a /4 sporto would be cool there's lots to consider. A sporto box would likely be sourced from a 911 and would need the ring gear flipped. You also need to find a vacuum tank and servo, the special shifter with the electrical contacts and maybe a fluid reservoir since the /6 used the engine oil tank. You'd need to figure out how to circulate oil for the convertor. The /6 used a pump driven off the end of the camshaft but a pump was never developed for a 914/4. You may be able to use something like the double pump from a VW autostick but will likely run into clearance problems with the engine support bar like you do with a dry sump pump. A few of the reasons why I don't think we've ever seen a /4 converted to sportomatic. A full auto from an inline engine front wheel drive VW/Audi is much easier since everything is in the box. 1.8T from an A4 automatic... Paging Andrew Dalen... (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/bye1.gif) @Andyrew |
Andyrew |
Nov 22 2021, 09:15 PM
While a /4 sporto would be cool there's lots to consider. A sporto box would likely be sourced from a 911 and would need the ring gear flipped. You also need to find a vacuum tank and servo, the special shifter with the electrical contacts and maybe a fluid reservoir since the /6 used the engine oil tank. You'd need to figure out how to circulate oil for the convertor. The /6 used a pump driven off the end of the camshaft but a pump was never developed for a 914/4. You may be able to use something like the double pump from a VW autostick but will likely run into clearance problems with the engine support bar like you do with a dry sump pump. A few of the reasons why I don't think we've ever seen a /4 converted to sportomatic. A full auto from an inline engine front wheel drive VW/Audi is much easier since everything is in the box. 1.8T from an A4 automatic... Paging Andrew Dalen... (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/bye1.gif) @Andyrew It would be a relatively easy conversion to any VAG engine. |
Lo-Fi Version | Time is now: 5th May 2024 - 12:34 PM |
