Synchro in 1st gear? |
Gatornapper |
Nov 23 2021, 07:08 AM
Senior Member Group: Members Posts: 1,205 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States |
Please forgive me in advance for asking a stupid question:
Did the new/original 914 tranny have synchro in 1st gear? Got mine with 60k original miles and it did not, nor have I ever driven one that did have a synchro 1st. But somewhere I read something that said synchro in 1st went out quickly - and then synchro in 2nd would go out. I have no synchro in 1st, but if it existed originally, that alone wouid be worth my rebuilding the tranny. Maybe Dr. Evil will do another one of his rebuild sessions at Scotty Burnett's? Synchro in 2nd has a mind of its own. 1st to 2nd - it works 60% of the time fine. 30%, I get a tiny crunch. 10%, I get a bad crunch. Tried everything - nothing I do seems to affect whether it will crunch or not. Downshifts into 2nd are another thing. 60% of the time, downshifts are perfect. Like a new tranny. 40% of the time, they are a horrible crunch. No idea why. Yes - clutch pressed all the way down. No problems with any other synchros, tho 3rd, coming from 2nd, takes some additional physical effort to get into gear for some reason. TIA, GN |
Shivers |
Nov 23 2021, 07:34 AM
Senior Member Group: Members Posts: 2,365 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
"The 901 transmission has a synchro-mesh mechanism which allows the gears to be shifted when the car and the transmission are spinning at different speeds. There are 6 main components used in 1st gear. These are the slider, shift fork, synchro ring and brake band, dog teeth, and 1st gear. "
I don't shift into 1st moving. If it is being stubborn, I shift into 2nd then slip it into 1st. 50 year old trans may need some love. https://www.pelicanparts.com/techarticles/9...anny_repair.htm |
Gatornapper |
Nov 23 2021, 07:48 AM
Wow. over 4 years as a 914'er and no one ever told me this. As I grew up driving stick with no synchro in 1st it was quite normal to me.
Thank you. Now to figure when I can find time to rebuild tranny......will have to wait - 924 Turbo is my main focus now. Will be so wonderful to drive my 914 with a synchro in 1st......... GN "The 901 transmission has a synchro-mesh mechanism which allows the gears to be shifted when the car and the transmission are spinning at different speeds. There are 6 main components used in 1st gear. These are the slider, shift fork, synchro ring and brake band, dog teeth, and 1st gear. " I don't shift into 1st moving. If it is being stubborn, I shift into 2nd then slip it into 1st. 50 year old trans may need some love. https://www.pelicanparts.com/techarticles/9...anny_repair.htm |
Superhawk996 |
Nov 23 2021, 08:10 AM
914 Guru Group: Members Posts: 5,769 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
As I grew up driving stick with no synchro in 1st it was quite normal to me. As a generalized statement, almost all transmissions since 70's have had syncrhronized 1st gear. Don't want to get into the age thing . . . (IMG:style_emoticons/default/smile.gif) Not aiming this at you but over the course of my career, I've had the opportunity to drive with hundreds if not almost a thousand people including automotive journalists, most can't drive a manual transmission worth a (IMG:style_emoticons/default/stromberg.gif) even if they think they can. There's a reason so many manual transmissions have bad gear and/or fried clutches every 50K miles. 1st gear is only used for getting off the line. . . that's it. Trying to shift from 2nd to 1st at anything other than a brisk walk is folly. Even modern transmissions prefer to be shifted from 2nd to 1st when just barely rolling before the stop, even with a synchronized 1st gear. |
Gatornapper |
Nov 23 2021, 08:24 AM
I am usually in neutral at stoplights. I rarely shift from 2nd to 1st and don't miss that.
My only desire is to got from neutral to 1st w/o the crunch at a stoplight. Of course, I do that by first putting the tranny in 2nd, using its synchros to stop the tranny gears from spinning, and then I go from neutral to 2nd then to 1st which is no problem as I always did that when young with 3 speed trannies. The PO of my 914 raced both 911's and 914's, and while he got my car as a gift for his girlfriend who was a professor at UVA, I'm sure he probably man-handled the shifting and messed up the synchros long before I got the car. GN As I grew up driving stick with no synchro in 1st it was quite normal to me. As a generalized statement, almost all transmissions since 70's have had syncrhronized 1st gear. Don't want to get into the age thing . . . (IMG:style_emoticons/default/smile.gif) Not aiming this at you but over the course of my career, I've had the opportunity to drive with hundreds if not almost a thousand people including automotive journalists, most can't drive a manual transmission worth a (IMG:style_emoticons/default/stromberg.gif) even if they think they can. There's a reason so many manual transmissions have bad gear and/or fried clutches every 50K miles. 1st gear is only used for getting off the line. . . that's it. Trying to shift from 2nd to 1st at anything other than a brisk walk is folly. Even modern transmissions prefer to be shifted from 2nd to 1st when just barely rolling before the stop, even with a synchronized 1st gear. |
Superhawk996 |
Nov 23 2021, 08:45 AM
I am usually in neutral at stoplights. I rarely shift from 2nd to 1st and don't miss that. My only desire is to got from neutral to 1st w/o the crunch at a stoplight. Of course, I do that by first putting the tranny in 2nd, using its synchros to stop the tranny gears from spinning, and then I go from neutral to 2nd then to 1st which is no problem as I always did that when young with 3 speed trannies. There are pro's and con's to being in neutral at stoplights. Not sure I really want to go into all that here. The quickies. The downside of doing that is: 1) Lost ability to go from 2nd into 1st as you roll to a stop minimzing wear on the synchro. Avoids the problem of using the 1st gear synchro with high differential shaft speeds at every stop. 2) If the light changes unexpectedly you'll be "speed shifting" from neutral to 1st, stressing the 1st gear synchro, and in a 901 gearbox, the dog leg doesn't help things to get a quick smooth, quick shift to 1st. As it stands now, you're just wearing out the 2nd gear synchro instead of the 1st gear synchro. 3) Inability to move forward quickly if someone is going to rear end you (assuming traffic is clear and allows that forward move) As a motorcyclist, I almost always stay in gear. Always need to be prepared to move if needed to stay alive. The advantages of being in neutral at light: 1) Less wear and stress on throwout bearing, clutch cable, clutch disk, pressure plate. Personally, I think these are preferrable to replace vs. a transmission rebuild. 2) Get to relax left leg. 3) In some rare instance that clutch cable breaks without warning, no possibility of car lurching into traffic. Pretty low risk. At idle, dumping the clutch will usually just stall the car but agree that it might move a foot or so. To each his own, each approach has it's own problems. |
Lo-Fi Version | Time is now: 2nd May 2024 - 11:48 PM |
