Synchro in 1st gear? |
Gatornapper |
Nov 23 2021, 07:08 AM
Senior Member Group: Members Posts: 1,205 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States |
Please forgive me in advance for asking a stupid question:
Did the new/original 914 tranny have synchro in 1st gear? Got mine with 60k original miles and it did not, nor have I ever driven one that did have a synchro 1st. But somewhere I read something that said synchro in 1st went out quickly - and then synchro in 2nd would go out. I have no synchro in 1st, but if it existed originally, that alone wouid be worth my rebuilding the tranny. Maybe Dr. Evil will do another one of his rebuild sessions at Scotty Burnett's? Synchro in 2nd has a mind of its own. 1st to 2nd - it works 60% of the time fine. 30%, I get a tiny crunch. 10%, I get a bad crunch. Tried everything - nothing I do seems to affect whether it will crunch or not. Downshifts into 2nd are another thing. 60% of the time, downshifts are perfect. Like a new tranny. 40% of the time, they are a horrible crunch. No idea why. Yes - clutch pressed all the way down. No problems with any other synchros, tho 3rd, coming from 2nd, takes some additional physical effort to get into gear for some reason. TIA, GN |
Rand |
Nov 26 2021, 09:12 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
And third to first? Yes, much nicer.
You do need to make sure your linkage is spiff and adjusted. And no weakness at the firewall where the clutch cable comes through. And... I hope you don't have to dig into the transmission for synchros and such.... Although, do it and you're good forever. |
Gatornapper |
Nov 27 2021, 09:14 AM
Rand -
I cannot imagine my linkage being any tighter than it is. I totally rebuilt the linkage a couple years ago and made some additional improvements of my own where I removed some slack/slop that was left even with all new bushings/fittings. RickB45 has a totally restored '72 2.0 with all new bushings and my linkage is much tighter than his. Linkage very tight at firewall. Still not clear - sorry: can I drop tranny behind differential w/o dropping clutch & differential? Leaving clutch housing, differential & axles in place? TIA again, GN And third to first? Yes, much nicer. You do need to make sure your linkage is spiff and adjusted. And no weakness at the firewall where the clutch cable comes through. And... I hope you don't have to dig into the transmission for synchros and such.... Although, do it and you're good forever. |
Lo-Fi Version | Time is now: 3rd May 2024 - 08:05 AM |
