Oil leak? |
Oil leak? |
Shredhead |
Nov 24 2021, 01:08 PM
Member Group: Members Posts: 110 Joined: 10-August 15 From: CT Member No.: 19,047 Region Association: North East States |
windforfun |
Nov 24 2021, 01:15 PM
Senior Member Group: Members Posts: 1,775 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Did you spill your beer again?
(IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) |
Wew |
Nov 24 2021, 02:51 PM
Member Group: Members Posts: 227 Joined: 17-January 15 From: Novato, ca Member No.: 18,335 Region Association: None |
Read my recent thread on oil leaks.
This looks like the similar spot I am experiencing on both sides. Since I just did a new rebuild my tins are spotless but nevertheless under them in that spot are little puddles of oil. Conventional wisdom says its the valve cover gaskets. On pelican's forums there is an article of how to address this by welding 24 gauge. steel onto the inner lip of the valve covers to keep the cork gaskets in place. I should be getting my materials shortly and will be doing this. I will report back when I am finished and hopefully have nothing but stellar results to share. |
Shredhead |
Nov 24 2021, 08:21 PM
Read my recent thread on oil leaks. This looks like the similar spot I am experiencing on both sides. Since I just did a new rebuild my tins are spotless but nevertheless under them in that spot are little puddles of oil. Conventional wisdom says its the valve cover gaskets. On pelican's forums there is an article of how to address this by welding 24 gauge. steel onto the inner lip of the valve covers to keep the cork gaskets in place. I should be getting my materials shortly and will be doing this. I will report back when I am finished and hopefully have nothing but stellar results to share. Thanks, that's probably it. |
Lo-Fi Version | Time is now: 25th April 2024 - 04:24 PM |
