Trying to pay it forward – friends 914 is popping out fourth and fifth gear |
Tdskip |
Nov 24 2021, 07:04 PM
Advanced Member Group: Members Posts: 3,684 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
First of all best wishes for a great Thanksgiving tomorrow, and for those in the rest of the world forgive us if we’re a bit sluggish on our keyboards tomorrow due to food induced comas.
I’m trying to help a friend out with a new to him 914 that came with a vague description of transmission problems. The gearbox was super sloppy so we got the car in the air and I explained to him how important it was that it had fresh in correct bushings and set screws in the linkage so we took it all apart and put new parts in and adjusted the shift pattern. The good news is that the gearbox was transformed in the shift action, just as you would expect it to be, and we can get reversed, first, second, third cleanly but fourth and fifth keep popping out of gear. You can find the slot for fourth and fifth but it just won’t stay in gear gear. Reverse through 3rd are in the normal place with the gear lever, so I don’t think I’ve got the rod misaligned. I checked the clutch tube and I don’t think we’re getting movement on that, so I am getting that sick to my stomach feeling that it’s an internal to the box issue.. Any ideas or suggestions on something that I may be missing? |
Shivers |
Nov 24 2021, 07:15 PM
Senior Member Group: Members Posts: 2,347 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Tail shift?
Mikey914 |
Nov 24 2021, 07:21 PM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Either the cone screw is backed out or more likely the shift knuckle bushings are shot.
PM me an address I’ll drop one set out. (IMG:style_emoticons/default/welcome.png) Attached thumbnail(s) |
Tdskip |
Nov 24 2021, 08:12 PM
Hi guys, thanks for the responses.
Side shifter. Cone screws are in place and snug. Coupler bushings are new and tight. |
914Mels |
Nov 24 2021, 09:01 PM
Member Group: Members Posts: 357 Joined: 20-June 11 From: Santee Member No.: 13,221 Region Association: Southern California |
Happy Thanksgiving! For what its worth, I'd have your friend work the shifter while you watch the shift linkage at the trans with the motor off and compare the movements between 2-3 and 4-5. 4th and 5th usually get the least amount of wear so hopefully it's still an adjustment issue in the linkage.
NARP74 |
Nov 24 2021, 09:32 PM
Senior Member Group: Members Posts: 1,050 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
Motor mounts, trans mounts?
Mikey914 |
Nov 24 2021, 10:08 PM
If the knuckle is good, it must just be out of adjustment. Pretty easy fix.
Tdskip |
Nov 25 2021, 12:25 PM
Thanks for the suggestions, will try again!
Lo-Fi Version | Time is now: 25th April 2024 - 12:02 PM |
