How do I fix my fuel level sender? |
andreic |
Nov 25 2021, 11:16 AM
Member Group: Members Posts: 172 Joined: 21-December 15 From: Madison, WI Member No.: 19,479 Region Association: Upper MidWest |
My 1972 1.7L 914 is in very good shape. But recently the fuel gauge will not go above indicating 1/2, even if the tank is full. Once the tank goes below 1/2 or 1/3, it will start indicating correctly.
I suspect it is some part in the fuel tank sender that should be sliding up and down with the fuel level, and is getting stuck half-way. Any suggestions on how to fix? Thanks, Andrei. |
wndsrfr |
Nov 25 2021, 11:23 AM
Senior Member Group: Members Posts: 1,428 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
My 1972 1.7L 914 is in very good shape. But recently the fuel gauge will not go above indicating 1/2, even if the tank is full. Once the tank goes below 1/2 or 1/3, it will start indicating correctly. I suspect it is some part in the fuel tank sender that should be sliding up and down with the fuel level, and is getting stuck half-way. Any suggestions on how to fix? Thanks, Andrei. Really easy to pull it out and likely there's a bit of rust jamming it...i'd suggest you get a used one from Brad Stone or Garold or another vendor ....check the for sale 914 parts...just swap them... |
Lo-Fi Version | Time is now: 4th May 2024 - 10:19 AM |
