Late window issues, Drivers window rolls down too far |
joeswaim |
Nov 25 2021, 11:36 AM
Newbie Group: Members Posts: 5 Joined: 4-December 15 From: Roswell Ga Member No.: 19,433 Region Association: South East States |
I have a 1973 with the late model window mechanisms.
If I roll down the window too far, when I go to lift the window, the regulator gear jumps the teeth. With the door panel off, I can get under the glass and lift it up a little to relieve the stress and it rolls up fine. This is the drivers side. The passengers side works great. I don’t think that anything is missing, but something is worn out or not adjusted or needs lubrication. Any experiences out there? Thanks Joe |
Literati914 |
Nov 25 2021, 06:31 PM
Senior Member Group: Members Posts: 1,443 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
Is the glass still glued (or whatever the black sticky stuff is) into the horizontal channel at the bottom? Mine has come loose on one of my projects, and I’ll need to get that figured out… but I could see it causing problems when rolling window to its lowest point.
joeswaim |
Nov 25 2021, 08:05 PM
Is the glass still glued (or whatever the black sticky stuff is) into the horizontal channel at the bottom? Mine has come loose on one of my projects, and I’ll need to get that figured out… but I could see it causing problems when rolling window to its lowest point. . I pulled out the window regulator and two teeth are worn at the place the window needs help going up. So, it is to replace the regulator or try to repair by welfding material to the teeth and grinding it down to size. Any ideas? |
bdstone914 |
Nov 25 2021, 09:42 PM
bdstone914 Group: Members Posts: 4,515 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Is the glass still glued (or whatever the black sticky stuff is) into the horizontal channel at the bottom? Mine has come loose on one of my projects, and I’ll need to get that figured out… but I could see it causing problems when rolling window to its lowest point. @joeswaim I pulled out the window regulator and two teeth are worn at the place the window needs help going up. So, it is to replace the regulator or try to repair by welfding material to the teeth and grinding it down to size. Any ideas? I have plenty of good used regulators. Easier to bolt in a new one |
Lo-Fi Version | Time is now: 4th May 2024 - 08:44 AM |
