Members with 74 1.8, information needed for history of cars |
wonkipop |
Nov 25 2021, 04:35 PM
Advanced Member Group: Members Posts: 4,253 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
@StarBear & @wonkipop want to hear from members who own 1974 1.8s.
to assist with a topic in originality section of the website. Cars need to be reasonably original with L jet fuel injection system intact. If you have the time and can help us with some information it would be great. information. 1. Vin Date - month and year (no need to post vin numbers if you don't want to). thats the date on the driver door sticker. 2. Karmann plate #. or if you have already done the maths, the day and week of the year the car began production. 3. Image of engine bay emission sticker (lhs above the air cleaner - white with red letters). sticker should say whether it is an EC-A or an EC-B engine and whether it is california + EPA or only EPA. 4. image of engine tune up sticker. this is the small white sticker that is on LHS engine tin just below fan shroud. most of them are gone by now, but some engines still have them. 5. image of the throttle body. image of the distributor. we are looking at the vacuum hose set up between the distributor and the throttle body. ----- (IMG:style_emoticons/default/beerchug.gif) |
L-Jet914 |
Nov 28 2021, 12:54 AM
Member Group: Members Posts: 237 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California |
I don't why the vacuum T was installed in between with the fuel pressure regulator and decel valve was done to connect the retard side of the vacuum port of my distributor. The port on my throttle body is capped off as pictured. I do know the engine had some major work done to it in the 80s cylinder heads etc. So it now has the configuration of two vacuum t's connected to the manifold vacuum port off the intake plenum giving vacuum to the retard side of the distributor, fuel pressure regulator and the decel valve, instead of just the decel valve and fuel pressure regulator.
Lo-Fi Version | Time is now: 2nd May 2024 - 04:21 PM |
