Is anyone still enlarging the diameter of our throttle bodies, Wouldn't it be nice to add a bit of power with a little more air?? |
second wind |
Nov 26 2021, 01:03 AM
Senior Member Group: Members Posts: 855 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
Happy Thanksgiving everyone....so I have seen this before but have never heard about the results.....is the idea any good? How do we get it done on our cars? Just thinking out loud....thank you (IMG:style_emoticons/default/smile.gif)
gg |
BeatNavy |
Nov 27 2021, 12:35 PM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
I believe @JamesM is running the Vanagon TB and plenum. I'd be interested in what's required to make that work. I can't find a good pic of one of those plenums, as I'd like to see what the vacuum outlet/port selection is like.
I think this is is rig. Very clean setup. But I can already see I'd probably have wiring harness issues with the way it's oriented. (IMG:http://www.914world.com/bbs2/uploads/post-5834-1576449659_thumb.jpg) |
JamesM |
Nov 27 2021, 11:11 PM
Senior Member Group: Members Posts: 1,900 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
I believe @JamesM is running the Vanagon TB and plenum. I'd be interested in what's required to make that work. I can't find a good pic of one of those plenums, as I'd like to see what the vacuum outlet/port selection is like. I think this is is rig. Very clean setup. But I can already see I'd probably have wiring harness issues with the way it's oriented. (IMG:http://www.914world.com/bbs2/uploads/post-5834-1576449659_thumb.jpg) Throttle body is 2.1 vanagon, the plenum and runners though are 74 1.8 parts. Only modification made was using a tailpipe expander to open up the plenum to match the 50mm vanagon TB, and swapping the throttle arm from a 1.8 throttle body over to the vanagon throttle body for proper throttle cable orientation. Using the Vanagon plenum is a bit more complicated as no 914 intake runners are a direct match to it. |
Montreal914 |
Nov 28 2021, 11:08 AM
Senior Member Group: Members Posts: 1,560 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
Throttle body is 2.1 vanagon, the plenum and runners though are 74 1.8 parts. Only modification made was using a tailpipe expander to open up the plenum to match the 50mm vanagon TB, and swapping the throttle arm from a 1.8 throttle body over to the vanagon throttle body for proper throttle cable orientation. Using the Vanagon plenum is a bit more complicated as no 914 intake runners are a direct match to it. And this is on a 2056? What kind of cam/head setup? Thanks! |
Lo-Fi Version | Time is now: 19th May 2024 - 01:57 PM |
