Is anyone still enlarging the diameter of our throttle bodies, Wouldn't it be nice to add a bit of power with a little more air?? |
second wind |
Nov 26 2021, 01:03 AM
Senior Member Group: Members Posts: 851 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
Happy Thanksgiving everyone....so I have seen this before but have never heard about the results.....is the idea any good? How do we get it done on our cars? Just thinking out loud....thank you (IMG:style_emoticons/default/smile.gif)
gg |
Geezer914 |
Nov 26 2021, 09:33 AM
Geezer914 Group: Members Posts: 1,393 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
Look on the Samba for a 2.1L Vanagon throttle body. They are 50mm vs 45. You have to modify the throttle shaft on your existing throttle body to fit the larger throttle plate in order to keep the TPS. I enlarged the plenum to 50 mm with a tail pipe expander and ordered a new gasket for a Vanagon. My engine is a 2056 using 1.8L plenum, runners, and Let fuel injection.
BeatNavy |
Nov 26 2021, 04:02 PM
Look on the Samba for a 2.1L Vanagon throttle body. They are 50mm vs 45. You have to modify the throttle shaft on your existing throttle body to fit the larger throttle plate in order to keep the TPS. I enlarged the plenum to 50 mm with a tail pipe expander and ordered a new gasket for a Vanagon I've seen this mentioned in threads before, primarily for the 1.8L plenum. Does anyone know of a good thread demonstrating how to do this on a 2.0? I'd love to open up air flow a bit for my 2270, not just for WOT but for getting more air at cold starts. |
Montreal914 |
Nov 26 2021, 10:23 PM
Senior Member Group: Members Posts: 1,545 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
Look on the Samba for a 2.1L Vanagon throttle body. They are 50mm vs 45. You have to modify the throttle shaft on your existing throttle body to fit the larger throttle plate in order to keep the TPS. I enlarged the plenum to 50 mm with a tail pipe expander and ordered a new gasket for a Vanagon I've seen this mentioned in threads before, primarily for the 1.8L plenum. Does anyone know of a good thread demonstrating how to do this on a 2.0? I'd love to open up air flow a bit for my 2270, not just for WOT but for getting more air at cold starts. @BeatNavy Rob, I tend to find more information on Shoptalkforums on this topic. Here's a thread looking at plenum efficiency and Vanagon TB. Seems appropriate for your 2270. (IMG:style_emoticons/default/smile.gif) But do some search there as there is a lot more information. Pyledriver seems pretty knowledgeable. https://shoptalkforums.com/viewtopic.php?t=102542 Definitely following closely all of your engine work/optimization. (IMG:style_emoticons/default/stirthepot.gif) (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 7th May 2024 - 12:33 AM |
