Is anyone still enlarging the diameter of our throttle bodies, Wouldn't it be nice to add a bit of power with a little more air?? |
second wind |
Nov 26 2021, 01:03 AM
Senior Member Group: Members Posts: 851 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
Happy Thanksgiving everyone....so I have seen this before but have never heard about the results.....is the idea any good? How do we get it done on our cars? Just thinking out loud....thank you (IMG:style_emoticons/default/smile.gif)
gg |
VaccaRabite |
Dec 1 2021, 09:44 AM
En Garde! Group: Admin Posts: 13,440 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
http://www.914world.com/bbs2/index.php?act...=2&t=353039
Here is my thread on moving from the stock TB to the GO-Westy unit. It shows all the steps needed to convert the unit (its EASY!) It also has my home built smoke tester for testing the intake. Bear in mind when I did this I id it for my Microsquirt 2056. So my TPS is a little different then the L-Jet unit that started on the 1.8, and may be a tad different then the TPS you use on your machine (but probably not, and its still super simple to make the bracket.) Zach |
Shivers |
Dec 1 2021, 10:00 AM
Senior Member Group: Members Posts: 2,368 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
http://www.914world.com/bbs2/index.php?act...=2&t=353039 Here is my thread on moving from the stock TB to the GO-Westy unit. It shows all the steps needed to convert the unit (its EASY!) It also has my home built smoke tester for testing the intake. Bear in mind when I did this I id it for my Microsquirt 2056. So my TPS is a little different then the L-Jet unit that started on the 1.8, and may be a tad different then the TPS you use on your machine (but probably not, and its still super simple to make the bracket.) Zach That was a good write up, and a clever idea on addressing the horn. Did it come out looking pretty stock? |
Lo-Fi Version | Time is now: 7th May 2024 - 11:52 AM |
