Would you use Por-15 on this..., ...or how else would you clean it up? |
Rick986 |
Nov 26 2021, 11:30 AM
0-60 in 14 seconds! Group: Members Posts: 141 Joined: 31-August 21 From: NE Ohio Member No.: 25,869 Region Association: Upper MidWest |
I've confirmed that this crap on the battery tray is not a fiberglass patch. PO obviously treated it with something as a preventative measure. HH is also solid, inside and under. The car is virtually rust-free.
I'm using a solvent to get the crap off the side wall and generally clean this area up the best possible (it's coming off - nice job, Stevie Wonder!). But the gunk on the tray is there to stay. Also, the acid corrosion on the side needs addressed (car sat for 8-9 years and battery seemingly "discharged"...thankfully, in a dry garage). So...I'm thinking of a fresh coat of Por-15 or similar on the tray and small "patch" over the surface rust on the sidewall, just to clean the whole area up. Is this sacrilege...or a decent solution short of a total tear-out and repainting (not gonna happen anytime soon)? Thanks...and hope you all had a great holiday. Attached thumbnail(s) |
dlee6204 |
Nov 26 2021, 07:28 PM
Howdy Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
I don’t understand the allure of POR-15. If you’re going to go through all the proper steps for POR-15 you might as well just clean it up and paint it correctly.
I suggest the following… 1. Wire wheel all the rust 2. Treat rust with Ospho 3. Sand 4. Paint with epoxy primer. You can get a two part epoxy in a single use can. $25 5. Paint with the correct color from a touch up can. Approximately $40 from various online suppliers. Order based on your color code. |
KELTY360 |
Nov 26 2021, 08:48 PM
914 Neferati Group: Members Posts: 5,031 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
I don’t understand the allure of POR-15. If you’re going to go through all the proper steps for POR-15 you might as well just clean it up and paint it correctly. I suggest the following… 1. Wire wheel all the rust 2. Treat rust with Ospho 3. Sand 4. Paint with epoxy primer. You can get a two part epoxy in a single use can. $25 5. Paint with the correct color from a touch up can. Approximately $40 from various online suppliers. Order based on your color code. I think this makes sense. That does not look like rust on the battery tray to me. Otherwise it would have eaten through at some point. I think it's a reaction to whatever coating the PO used. |
Lo-Fi Version | Time is now: 19th May 2024 - 04:57 AM |
