main bearings, preferred manufacturer |
930cabman |
Nov 27 2021, 09:55 AM
Advanced Member Group: Members Posts: 3,062 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
I recently purchased a standard size main bearing set from a large vendor, checking the clearances I am finding this new set will provide a clearance at the high limit per factory specs. My crank is spot on, but the main bearing ID appears too large. I can easily fit a .004 feeler between the crank and new bearing ID. Just for fun, I tried an old (used)main bearing and found it to have a smaller ID (by about .0015) than a new one. Am I missing something?
Thanks |
930cabman |
Nov 30 2021, 06:54 PM
Yes, as expected: I did assemble the crank/new main bearings with green Plasti gage in the #2 bearing. Torqued things up, took everything apart, measured between .002 and .003 with the green Plasti gage, cleaned the Plasti gage off, re assembled everything with a few drops of oil and the crank spins nice. Not super loose, but nice. Tomorrow I will take things apart again and look for and rubbing spots on the bearings. I suspect none.
Lo-Fi Version | Time is now: 15th May 2024 - 10:35 PM |
