main bearings, preferred manufacturer |
930cabman |
Nov 27 2021, 09:55 AM
Advanced Member Group: Members Posts: 3,003 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
I recently purchased a standard size main bearing set from a large vendor, checking the clearances I am finding this new set will provide a clearance at the high limit per factory specs. My crank is spot on, but the main bearing ID appears too large. I can easily fit a .004 feeler between the crank and new bearing ID. Just for fun, I tried an old (used)main bearing and found it to have a smaller ID (by about .0015) than a new one. Am I missing something?
Thanks |
Mark Henry |
Nov 28 2021, 01:06 PM
Yes the bearings is a torqued spec. Plastigauge is about the only way to do it. I also measure the bearing shell thickness in about 5 spots to make sure the surface is even. Porsche also does this on GT3 911 bearings, you can see the mark from measuring tool.
You could get the bearings coated, but it only adds about .0002 to .0004" to the babbit surface. |
Lo-Fi Version | Time is now: 29th April 2024 - 03:58 PM |
