FS: Parts Stash, Calipers, Gauges, 911 Crossmember, SBC-901 kit, more |
FL000 |
Nov 27 2021, 06:10 PM
Member Group: Members Posts: 386 Joined: 31-January 12 From: Lancaster, CA Member No.: 14,076 Region Association: Southern California |
Decided to stop hoarding extra parts. All prices are plus shipping. If you need more info or pics let me know. Everything is as shown.
1. 911 wide A calipers, rebuilt, low mileage $200/pair - sold 2. 914-4 rear calipers, $100/pair - sold 3. 24 mm 911 rotors, $40/pair 4. 914-4 rear rotors, drilled for 5 lug, $40/pair - sold 5. 911 front dust shields, $20/pair 6. 914 rear dust shields, $20/pair - sold 7. Gauge cluster (combo, tach, Speedo, panel), $100 - sold 8. Individual gauges $20 each - fuel, volt, temp gauge sold 9. 911 crossmember, $200 - sold 10. 5 x 130 x 1” aluminum spacers and lug nuts, $60/pair 11. Side shifter, $50 - sold 12. Dash defroster vents, $20/pair, small break on one but looks functional 13. SBC to 901 kit (engine to trans adapter, flywheel, pressure plate, clutch disk, starter), for 2 piece rear main seal type, $500 14. Renegade SBC water pump and mount, $60 - sold Attached image(s) |
FlacaProductions |
Nov 27 2021, 08:18 PM
Senior Member Group: Members Posts: 1,523 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
Messaged you
Nov 27 2021, 08:52 PM
914-6 GT in waiting Group: Members Posts: 19,142 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I’ll take the 911 crossmember if still available. Thanks
Steve |
Nov 27 2021, 08:57 PM
914 Guru Group: Members Posts: 5,548 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I’ll take fuel gauge and 914 5 bolt rear disks.
abes914 |
Nov 27 2021, 09:00 PM
Member Group: Members Posts: 366 Joined: 30-March 11 From: Long Beach Member No.: 12,880 Region Association: Southern California |
I’ll take the rear calipers if for late model. Also the rear dust shield please. Thanks
Literati914 |
Nov 27 2021, 09:45 PM
Senior Member Group: Members Posts: 1,396 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
Put me down for #4 drilled rotors if they're available, or become available..
orrzone |
Nov 28 2021, 12:47 AM
I'm new here ... Group: Members Posts: 0 Joined: 4-February 14 From: Central victoria Member No.: 16,954 Region Association: None |
Interested in gauge cluster and shifter
Will you post to Australia ? Thanks, John |
ValcoOscar |
Nov 28 2021, 08:38 AM
Garage Life Group: Members Posts: 2,366 Joined: 19-November 13 From: SoCal Member No.: 16,669 Region Association: Southern California |
sb914 |
Nov 28 2021, 09:01 AM
Surf Guru Group: Members Posts: 4,292 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California |
I’ll take the waterpump and bracket. I was going to pm you about your waterpump and here it is perfect timing…
sb914 |
Nov 28 2021, 09:02 AM
Thanks for the heads up Oscar
sb914 |
Nov 28 2021, 09:19 AM
I’m down for the starter as well if you want to sell separate?
Thanks josh… |
FL000 |
Nov 28 2021, 10:27 AM
A picture of the back of the clock that was requested.
FL000 |
Nov 28 2021, 10:59 AM
FL000 |
Nov 28 2021, 11:03 AM
I’ll take the waterpump and bracket. I was going to pm you about your waterpump and here it is perfect timing… Copy, w/p and bracket are reserved for you. I know there is not much of a market for the SBC-901 kit, but if you are not in a rush let me give the ad a couple weeks to see if anything materializes. If not I don't mind separating. Then I can ship as one package. Josh |
sb914 |
Nov 29 2021, 08:35 AM
I’ll take the waterpump and bracket. I was going to pm you about your waterpump and here it is perfect timing… Copy, w/p and bracket are reserved for you. I know there is not much of a market for the SBC-901 kit, but if you are not in a rush let me give the ad a couple weeks to see if anything materializes. If not I don't mind separating. Then I can ship as one package. Josh PayPal sent … |
HIPPIEKILLER |
Nov 29 2021, 11:18 AM
Member Group: Members Posts: 84 Joined: 25-July 17 From: Huntington Beach, CA Member No.: 21,286 Region Association: Southern California |
roundtwo |
Nov 29 2021, 12:20 PM
Member Group: Members Posts: 254 Joined: 9-February 20 From: Petaluma, CA Member No.: 23,905 Region Association: Central California |
I’d like the small volt and temp gauge if available. A little hard to tell by the picture but they look to be in decent condition.
Pm sent |
Hoppie944s2 |
Nov 29 2021, 12:33 PM
Porschenut Group: Members Posts: 64 Joined: 7-July 13 From: New Jersey Member No.: 16,098 Region Association: North East States |
.Ill take if not sold... Gauge cluster (combo, tach, Speedo, panel), $100 - sale pending
FL000 |
Nov 29 2021, 08:43 PM
I’d like the small volt and temp gauge if available. A little hard to tell by the picture but they look to be in decent condition. Pm sent Here are a couple more pics for you @roundtwo . Bezels could use some touching up, but face and dial look good (to me anyways). They currently have LED bulbs and I may have the original if that is your preference. |
roundtwo |
Nov 30 2021, 12:21 PM
Thank you. I’ll take them with LEDS. Pm sent. Todd
Lo-Fi Version | Time is now: 29th March 2024 - 04:07 AM |
