FS: Parts Stash, Calipers, Gauges, 911 Crossmember, SBC-901 kit, more |
FL000 |
Nov 27 2021, 06:10 PM
Member Group: Members Posts: 389 Joined: 31-January 12 From: Lancaster, CA Member No.: 14,076 Region Association: Southern California |
Decided to stop hoarding extra parts. All prices are plus shipping. If you need more info or pics let me know. Everything is as shown.
1. 911 wide A calipers, rebuilt, low mileage $200/pair - sold 2. 914-4 rear calipers, $100/pair - sold 3. 24 mm 911 rotors, $40/pair 4. 914-4 rear rotors, drilled for 5 lug, $40/pair - sold 5. 911 front dust shields, $20/pair 6. 914 rear dust shields, $20/pair - sold 7. Gauge cluster (combo, tach, Speedo, panel), $100 - sold 8. Individual gauges $20 each - fuel, volt, temp gauge sold 9. 911 crossmember, $200 - sold 10. 5 x 130 x 1” aluminum spacers and lug nuts, $60/pair 11. Side shifter, $50 - sold 12. Dash defroster vents, $20/pair, small break on one but looks functional 13. SBC to 901 kit (engine to trans adapter, flywheel, pressure plate, clutch disk, starter), for 2 piece rear main seal type, $500 14. Renegade SBC water pump and mount, $60 - sold Attached image(s) |
sb914 |
Nov 28 2021, 09:01 AM
Surf Guru Group: Members Posts: 4,296 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California |
I’ll take the waterpump and bracket. I was going to pm you about your waterpump and here it is perfect timing…
FL000 |
Nov 28 2021, 11:03 AM
I’ll take the waterpump and bracket. I was going to pm you about your waterpump and here it is perfect timing… Copy, w/p and bracket are reserved for you. I know there is not much of a market for the SBC-901 kit, but if you are not in a rush let me give the ad a couple weeks to see if anything materializes. If not I don't mind separating. Then I can ship as one package. Josh |
sb914 |
Nov 29 2021, 08:35 AM
I’ll take the waterpump and bracket. I was going to pm you about your waterpump and here it is perfect timing… Copy, w/p and bracket are reserved for you. I know there is not much of a market for the SBC-901 kit, but if you are not in a rush let me give the ad a couple weeks to see if anything materializes. If not I don't mind separating. Then I can ship as one package. Josh PayPal sent … |
Lo-Fi Version | Time is now: 28th April 2024 - 02:11 PM |
