914 rear caliper need advice, vented rear rotor |
jim dorociak |
Nov 28 2021, 08:00 PM
Member Group: Members Posts: 95 Joined: 23-January 09 From: Newbury Park, Ca Member No.: 9,966 Region Association: Southern California |
I have fresh replated, and rebuild 914/4 rear calipers and thought I would run 911SC vented rear rotor, am running 911 Carrera front vented rotors and figured easy upgrade for the rear. I got spacer blocks from rear 911 calipers, but upon disassembly of the 914/4 calipers I discovered the bolt holes do not line up properly for the spacer blocks I already bought. Does anyone make a kit of spacer blocks for 914/4 to allow a vented rear rotor to be used? I already turned down the overall diameter of the vented rear rotor to 914 size. Trying not to purchase 914-6 rear calipers because of the cost.
Help please with some information and knowledge from you guys. Thanks in advance. Jim Dorociak. jdorociak@gmail.com |
Mark Henry |
Dec 1 2021, 10:49 AM
I have PMB V-calipers, last I checked Eric doesn't make them anymore.
They came with no hardware and after no reply with repeated emails I made my own. I also have another 914 with 5 bolt, but stock rears. IMHO unless you're racing rear vented rotors are not needed. |
Lo-Fi Version | Time is now: 18th May 2024 - 06:52 AM |
