Another stupid d-jet question:, Related to a new 2.1 tune: defining terms- what constitutes "part-load vs full-load" and other mysteries |
DRPHIL914 |
Nov 29 2021, 08:06 AM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
calling all d-jet masters ! OK so yes, ive read Anders etc and maybe missed it along the way, but how or what constitutes a part-load condition? I am trying to get my d-jet MPS dialed in on the 2.1 build. and it had been running really well, but just a tad lean still, so after going back and reverifying my timing and other settings, checking plugs aftera 750 mile trip, its really close and realizing i was probably a bit low on the fuel pressure i made that correction and then set out to do some local highway driving to test it out, and really felt good, but maybe a bit rich at low end, idle and what i was thinking would be part-load. BUT i think i over corrected on the MPS and now i went from being in the 12-12.5 range at idle and also cruising at 3000-3400rpm, i now am running light at about 14 on that mid-range cruising. it is good on WOT so i dont want to mess with that(full load stop) . i should have left well enough alone because i will probably be a bit heavy at idle and low end with this motor, due to a more performance minded cam profile etc. point is, what is part-load? if i am reading my AFR meter , lets say at 3000rpm- 3400rpm and cruising on the flat, that would be part- load condition correct? so i dont want to make it more rich at cruise or on WOT, so how can i isolate the mid range or par-load to enrich it with out messing anything else up. i already messed this up trying to just lean it out slighty and over corrected. if i adjust the inner screw by itself it changes both part and full load. the outer screw in will richen part load i believe lean out full- load. the Anders chart doesnt really address it. - also i feel i cant really get idle right, it seems too rich but that might be the way the motor will be, not sure. the MPS is a rebuilt one with Tangerine kit and adjustor screws, so easy to access and adjust using the Tangerine tools. I may be at the point of just going dual webber with 44 IDF's, and forsaking the d-jet - OR a more modern programable EFI...... i just dont think i am getting the most power out of this motor that i should or would with better air intake and A/F mix. intake is somewhat restricted on a stock d-jet and the injectors can only give you so much fuel. i did see somewhere anders wrote that the stock set up could support a build up to 2270 even with the proper changes( not sure what that means either), anyway first question is - part load definition. then how to proceed to get this mid-range or par-load adjusted into a better mix with out making idle even more rich(or WOT either) Thanks for the help. Phil |
BeatNavy |
Dec 1 2021, 06:55 AM
(IMG:style_emoticons/default/agree.gif) with this and with Rob's ( @914_Teener ) point about Jake's advice to "give the engine what it wants." When you go beyond stock you are in unchartered territory to some extent. In your case in particular, a CR of 9.5 is well outside what Jake recommends for that cam/FI combo (he suggests around 8.5, max). That doesn't mean you can't make it work for your specific combo, and it sounds like you are to a large degree, but it requires a lot of measuring and trial and error. IMO you really need an LCR and and an understanding of how much vacuum you're pulling under different driving conditions. In terms of idle, I'll suggest it one more time: try not to obsess over a specific 'ideal' idle AFR.
DRPHIL914 |
Dec 2 2021, 08:47 AM
(IMG:style_emoticons/default/agree.gif) with this and with Rob's ( @914_Teener ) point about Jake's advice to "give the engine what it wants." When you go beyond stock you are in unchartered territory to some extent. In your case in particular, a CR of 9.5 is well outside what Jake recommends for that cam/FI combo (he suggests around 8.5, max). That doesn't mean you can't make it work for your specific combo, and it sounds like you are to a large degree, but it requires a lot of measuring and trial and error. IMO you really need an LCR and and an understanding of how much vacuum you're pulling under different driving conditions. In terms of idle, I'll suggest it one more time: try not to obsess over a specific 'ideal' idle AFR. yea, i am concentrating on my afr readings during part and full load and it’s really close now, so if reading at idle is a bit rich that’s fine, as you say it may not be accurate, now i need to see why my idle is so low, or why i need that idle screw out that far. so will do a recheck on the vac like you suggested and check my advance at idle , then may reconsider the curve i’m using and as rob is saying maybe put the vac line back on and change the curve setting back to either 3 or 4. here is the chart from 123 Attached thumbnail(s) |
Lo-Fi Version | Time is now: 7th May 2024 - 07:39 PM |
