Another stupid d-jet question:, Related to a new 2.1 tune: defining terms- what constitutes "part-load vs full-load" and other mysteries |
DRPHIL914 |
Nov 29 2021, 08:06 AM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
calling all d-jet masters ! OK so yes, ive read Anders etc and maybe missed it along the way, but how or what constitutes a part-load condition? I am trying to get my d-jet MPS dialed in on the 2.1 build. and it had been running really well, but just a tad lean still, so after going back and reverifying my timing and other settings, checking plugs aftera 750 mile trip, its really close and realizing i was probably a bit low on the fuel pressure i made that correction and then set out to do some local highway driving to test it out, and really felt good, but maybe a bit rich at low end, idle and what i was thinking would be part-load. BUT i think i over corrected on the MPS and now i went from being in the 12-12.5 range at idle and also cruising at 3000-3400rpm, i now am running light at about 14 on that mid-range cruising. it is good on WOT so i dont want to mess with that(full load stop) . i should have left well enough alone because i will probably be a bit heavy at idle and low end with this motor, due to a more performance minded cam profile etc. point is, what is part-load? if i am reading my AFR meter , lets say at 3000rpm- 3400rpm and cruising on the flat, that would be part- load condition correct? so i dont want to make it more rich at cruise or on WOT, so how can i isolate the mid range or par-load to enrich it with out messing anything else up. i already messed this up trying to just lean it out slighty and over corrected. if i adjust the inner screw by itself it changes both part and full load. the outer screw in will richen part load i believe lean out full- load. the Anders chart doesnt really address it. - also i feel i cant really get idle right, it seems too rich but that might be the way the motor will be, not sure. the MPS is a rebuilt one with Tangerine kit and adjustor screws, so easy to access and adjust using the Tangerine tools. I may be at the point of just going dual webber with 44 IDF's, and forsaking the d-jet - OR a more modern programable EFI...... i just dont think i am getting the most power out of this motor that i should or would with better air intake and A/F mix. intake is somewhat restricted on a stock d-jet and the injectors can only give you so much fuel. i did see somewhere anders wrote that the stock set up could support a build up to 2270 even with the proper changes( not sure what that means either), anyway first question is - part load definition. then how to proceed to get this mid-range or par-load adjusted into a better mix with out making idle even more rich(or WOT either) Thanks for the help. Phil |
emerygt350 |
Dec 2 2021, 09:09 AM
Advanced Member Group: Members Posts: 2,087 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
I bet you are a bit low on your timing. Have you tried adjusting your timing till you get a good idle (850) and giving that a try?
DRPHIL914 |
Dec 2 2021, 02:29 PM
I bet you are a bit low on your timing. Have you tried adjusting your timing till you get a good idle (850) and giving that a try? was at stock 27 degrees@3400rpm and verified before slightly increasing it which helped but i have to go back and recheck it at idle too and see what its at at 900rpm - one other factor thats going to effect that is the richness/leaness at idle, thats why the true AF at idle matters too. hope to get to check it tonight. |
BeatNavy |
Dec 2 2021, 03:03 PM
JamesM |
Dec 2 2021, 04:49 PM
Senior Member Group: Members Posts: 1,895 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
one other factor thats going to effect that is the richness/leaness at idle, thats why the true AF at idle matters too. Idle mixture matters. You just shouldn't put too much stock in what your AFR gauge is telling you at idle. (IMG:style_emoticons/default/agree.gif) THAT^^^ Depending on the placement of your wideband or your type of exhaust your readings at idle could be totally out of whack. With d-jet I would dial idle in by ear or vacuum gauge rather than AFR. Twist the idle knob to lean until the engine starts hunting at idle and then move it back rich one or two clicks and you should be good to go. setup cruise and WOT by AFR but idle by where it runs best. |
Lo-Fi Version | Time is now: 7th May 2024 - 08:59 AM |
