Doctor GoQuik, calling Doctor GoQuik, Questions from the bleachers |
mlindner |
Dec 18 2021, 09:49 AM
Senior Member Group: Members Posts: 1,515 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
Mine are raised 16mm and it did rub on the 15 inch rims....the spacers just made it work.
Cracker |
Dec 18 2021, 10:06 AM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
@ChrisFoley
Its been a LONG time now but I believe you moved mine 30mm ~ I am too old and not enough left in the mental hard drive to recall without notes. My car is very much still a street car and it works just fine at that ~ I also run 17" rims. You may not want to get even that aggressive - as I mentioned previously, Mr. Foley would be your best resource. Cracker |
Shivers |
Dec 18 2021, 10:32 AM
Senior Member Group: Members Posts: 2,364 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
@ChrisFoley Its been a LONG time now but I believe you moved mine 30mm ~ I am too old and not enough left in the mental hard drive to recall without notes. My car is very much still a street car and it works just fine at that ~ I also run 17" rims. You may not want to get even that aggressive - as I mentioned previously, Mr. Foley would be your best resource. Cracker I will be real interested to see what he says, after knowing what is going on the car. If 30mm will do it, I'm all in. I have not pressed them yet. Last build for me, just want to get it right. |
ChrisFoley |
Dec 19 2021, 05:42 AM
I am Tangerine Racing Group: Members Posts: 7,919 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
With 17s its probably safe to go 30mm without having the wheels in hand. Any more would require more careful setup measurements.
Are your struts Boge or Bilstein? The Bilsteins might have been made with a different spindle height than the Boges. |
Shivers |
Dec 19 2021, 06:41 AM
With 17s its probably safe to go 30mm without having the wheels in hand. Any more would require more careful setup measurements. Are your struts Boge or Bilstein? The Bilsteins might have been made with a different spindle height than the Boges. @ChrisFoley Thanks Chris. They are Bilsteins B6 HD's : Only pic I seem to have. |
Lo-Fi Version | Time is now: 2nd May 2024 - 01:06 AM |
